Old 06-19-2011, 03:25 PM   #1
paujones
Header and exhaust kit for a new roller 383
Guys,
I just replace the 350 in my dad's 69 C-10 2WD with a 383 stroker. I ended up using the stock exhaust manifolds with the old set of glasspacks to get it running and drivable. The truck has a mild 2/4 drop springs on it and I dont plan on laying it all the way down any time soon.
I'm ready to install the performance exhaust and I wanted to get some advice from the gurus on the board.
At a minimum, I want something thermal coated, at least 1 5/8" primary tubes and a set of full flow mufflers. After that I am wide open to what works, fits best and is cost effective.
I'm leaning toward a set of Hedman Elite 1 5/8 x 30" with 3" collectors, a 2.5" aluminized steel pipes, crossover, dual flowmaster 50-series, and side tips before the rear tires.
I've seen the Magnaflow kit - header back, x pipe, dual magnaflow mufflers and pipes - $579. Or a few other kits that dont include the mufflers in the $250 range. I could just take it to the local Minute muffler and have them fab something up... but I'm thinking with headers, pipes, mufflers, tips and install, I'm looking at $1000.
What are you 383 guys running?
Does the cross over kit make much performance or sound difference?
Where are you putting your cross-over - above the drive shaft, below it or ??
If you guys have pictures - please send them along too...
Thanks for the help!
Paul
1969 C-10 - 383, 700R4, 3.73 posi, still looks like a plain jane, but runs pretty well.
paujones is offline   Reply With Quote
Old 06-19-2011, 05:03 PM   #2
1972RedNeck
1972RedNeck's Avatar
Re: Header and exhaust kit for a new roller 383
I am running 2 1/2" ram horns and 2 1/2" 40 series Flowmasters. I myself don't really like headers. From what I've heard, keeping the bolts tight is a bit of a problem. The link below shows the difference between headers and ram horns.
http://www.chevytalk.org/fusionbb/sh...hp?tid/256915/
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
crossover, exhaust, headers, hedman, x-pipe
