06-19-2011, 09:18 PM | #1 |
72ChevyStep
Rear End
1972 Chevy C-10, 12-Bolt, 5-Lug Rear End, $100
06-22-2011, 09:33 PM | #2 |
72ChevyStep
Re: Rear End
ttt
06-23-2011, 12:28 PM | #3 |
Restoration Virgin!
Re: Rear End
is it a posi?? If so, what gears? would you remove the carrier and ship? if so, how much to 28031?
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
06-23-2011, 01:59 PM | #4 |
72ChevyStep
Re: Rear End
Not sure. Assume it is a 373. For a fact it is a 12 bolt with 5 lugs. Will ship if you make the arrangements for pickup.
06-23-2011, 03:10 PM | #5 |
Restoration Virgin!
Re: Rear End
So it sounds like you would rather sell the whole axle housing and not just the internal carrier/ gear?.....
06-23-2011, 04:32 PM | #6 | |
72ChevyStep
Re: Rear End
Value, $100? Last edited by tabarcus; 06-23-2011 at 04:38 PM. |
06-23-2011, 09:38 PM | #7 |
Restoration Virgin!
Re: Rear End
tabarcus....to remove the carrier, you'll have to pull the diff cover, pull the axles pin from the carrier, pull the axles, then remove the 2 caps on either side of the carrier and work it out.....BUT, I'm only interested in this if it's a POSI, you can tell this by looking for the codes on the ring gear, (which can be done after pulling the diff cover, should be on the outside of the gear...may have to spin the wheels)
OR if ya don't want to pull the cover, just jack up the rear, and spin one of the tires...if the other goes the same direction it's a posi, if it spins in the opposite direction, it's a an open rear
06-23-2011, 11:49 PM | #8 |
Re: Rear End
Terry, hows it going, seriously interested in the rear end. If I sent you the money could i wait till sometime in July to pick it up?
06-24-2011, 07:59 AM | #9 | |
72ChevyStep
Re: Rear End
06-24-2011, 07:54 PM | #10 |
Restoration Virgin!
Re: Rear End
no problem....if it falls thru and is posi, I'm still interested
