Old 06-21-2011, 06:51 PM   #1
heehawracing
heehawracing's Avatar
1987 chevy truck wont start
i have a 1987 chevy truck 350 throttle body all orginal it will not crank it will fire.. but the injectors will not work i have power on the hot side but it has no ground and i have changed the module thanks to any one with any info
heehawracing is offline   Reply With Quote
Old 06-21-2011, 06:59 PM   #2
Eyegore
What Hump?
Eyegore's Avatar
Re: 1987 chevy truck wont start
Need further explanation, it will not crank it will fire? If its not cranking then check battery, starter, cables to start with
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 06-21-2011, 07:14 PM   #3
heehawracing
it turns over the spark plugs fire but no ground to the injectors
thanks
Old 06-21-2011, 07:42 PM   #4
Goldfinger
Goldfinger's Avatar
Fuel,air, ignition. If you are getting power and air but it won't crank check the fuel etc. just trace it throughout the system ruling out possibilities
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 06-21-2011, 07:56 PM   #5
heehawracing
for the fuel injectors to work there is a positive and a ground it works off the ground the positive stays hot it is not getting a ground i am trying to find what to test next and how to test it the most common cause of this problem is the module i have replaced that so i dont know what to test next
thanks
Old 06-21-2011, 09:07 PM   #6
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Buddy of mine has a 90 Camaro with TBI that did almost the same thing. He could get it to fire up, but not stay running without gunning it the entire time. Turned out when we took his dash apart, we forgot to plug his anti-theft module back in. Does your truck have an anti theft in it?
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 06-21-2011, 09:14 PM   #7
sandorjoben
sandorjoben's Avatar
How long have you had the truck? I had the same problem when I got mine and found out a mystery unmarked switch I'd thrown in the truck a couple days after I bought it cut the power to the injector pod as an anti-theft feature added by a previous owner.
87 GMC V15 in profile photo sold 2013
99 Chev Silverado 2500 5.3 reg cab long bed
sandorjoben is offline   Reply With Quote
Old 06-21-2011, 09:23 PM   #8
rwhit57
rwhit57's Avatar
There is a pickup coil in the distributor, sounds possible, but too little info to be sure.
rwhit57 is offline   Reply With Quote
Old 06-21-2011, 09:51 PM   #9
heehawracing
it could be the pick up coil but im not sure if that would keep the injectors from working i think i have an extra distrubuter i will try it tomorrow because that will not cost anything
Old 06-21-2011, 09:59 PM   #10
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Have you made sure your fuel pump is working correctly yet? If your getting spark the pickup coil should be good.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-21-2011, 10:04 PM   #11
heehawracing
fuel pump is fine
Old 06-22-2011, 02:08 AM   #12
rfmaster
rfmaster's Avatar
Make sure that SES light goes from solid on - blink off - solid on as you move ignition key into run position ( before cranking). If SES does not come on check EFI fuse - very common problem. If ECM does not have +12 during cranking it will never fire injectors.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 06-28-2011, 09:38 AM   #13
jchav62
1962 C-10
jchav62's Avatar
//RF
I agree with this 100%. I had the same problem some years back in a Nevada D.O.T. survey rig ('90 GMC TBI 350).
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-27-2011, 11:56 AM   #14
skeebo23
same issue with mine last week, we replaced ignition module and map sensor and that fixed the problem
skeebo23 is offline   Reply With Quote
Old 06-28-2011, 05:54 AM   #15
lurch115
lurch115's Avatar
if the ignition module or pickup coil is bad the injectors will not work. if i remember correctly you can follow the wiring for the injectors and they plug directly into the ignition module.
sorry, i was thinking backwards. the coil plugs directly into the ignition module, not the injectors
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 06-28-2011, 08:38 AM   #16
skeebo23
the ignition module is located right under the distributor cap, remove cap (2 screws), and the module is along the backside held on by two bolts and 3 connections. very simple, just a little stretching to reach. Part is around $25.00
Old 06-28-2011, 07:54 PM   #17
Don SC
Don SC's Avatar
Actually, heehawracing, you should be seeing if the truck is throwing any codes so you can troubleshoot it more properly. Do you have an OBD1 code reader?
http://www.amazon.com/Equus-3123-GM-...9305208&sr=8-9
Don SC is offline   Reply With Quote
Old 06-28-2011, 08:22 PM   #18
rfmaster
rfmaster's Avatar
You do not need code reader - codes can be pulled by shorting pins A&B of ALDL connector. This will put ECM into diagnostic mode and if there are stored DTC's ECM will cause SES light to blink stored DTC code number.
//RF
"The Beast"
Old 07-11-2012, 08:49 AM   #19
Tonio327
Ok reading this and I have a 87 that's not starting but the injectors are working what can I rule out if the injectors are fine could it still be the ignition module r anything like that
Tonio327 is offline   Reply With Quote
Old 07-11-2012, 09:31 AM   #20
Don SC
Don SC's Avatar
You guys can throw parts at your trucks all day long and still not fix it. Why not just read what rfmaster and I are suggesting for you to do? Either a code reader for @ $25 or a FREE paper clip jumper at the ALDL connector under the dash -left hand side- .Jumper pin A to B with ignition on and watch the "check engine" light. It gives a flash, followed by 2 more flashes. That is a code 12. It tells you that the ecm is ok. Then if any other codes are stored in the ecm, they will flash also. Each code flashes 3 times. Write the code down and do a search on your computer at the following site.
http://www.extreme-check-engine-ligh...%20Decoder.htm
At least this way you'll be headed in the right direction for a fix.
On edit, remember, when you disconnect the battery you wipe out any codes that are store in the ecm.
Old 07-11-2012, 09:46 AM   #21
Tonio327
Will try this out I just got this one after my 82 was stolen it has the original motor but the dash has some issues will c if the egine light even lights up first I'm at square one again almost feel like saving for a crate and start from there hate learning everyone else rigged up stuff with a blind eye truck was starting find when I got it now I'm home and nothing
Old 07-11-2012, 09:52 AM   #22
heehawracing
I tried to check codes but could not get any anyway I put a new distributor in it and that fixed it
Old 07-11-2012, 09:49 AM   #23
Tonio327
Odd thing I just went to try the hold the gas padle down and start it and it turned over I turned it off and tried it again and nothing the injectors are working but I'm thinking it's still the throttle body
