Old 06-22-2011, 08:56 PM   #1
HSkinner
Anybody have any pics of the Boss 338's 20"
Pics and back spacing? So far this appears to be the best bang for the buck. Any thoughts? I really like this style. Heath
HSkinner is offline   Reply With Quote
Old 06-23-2011, 01:52 AM   #2
Slow Build
Slow Build's Avatar
Re: Anybody have any pics of the Boss 338's 20"
I like them a lot. Too bad you need to use spacers to run them.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 06-23-2011, 02:53 AM   #3
HSkinner
why do you have to use spacers?
Old 06-23-2011, 03:13 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Boss 338 wheel specs,...
http://www.bossmotorsports.com/wheel...ecs.cfm?id=408
6.225" BS on the 20x10's and 5.239" BS on the 20x8.5's.
The 10" rear wheel backspacing requires you to run a 1" spacer, depending on which rearend you have in the truck.
A larger spacer is required if you try to run the 20x8.5's on the rear of the truck.
(They are "tucked in" too far)
Up front the 20x8.5's are fine.
Have you seen this thread about front rotor fitment issues?
http://67-72chevytrucks.com/vboard/showthread.php?t=352320&highlight=boss+338
(It spans about 22 months starting in 2009)
Take a couple hours and read it.
Keith
Convert to disc brakes.
Old 06-23-2011, 04:51 AM   #5
HSkinner
I put the rear axle out of a 1996 impala so it is 1.5 inches narrower on each side. Will I still have to run spacers?
Old 06-23-2011, 04:54 AM   #6
lolife99
lolife99's Avatar
A narrower rear axle house makes the problem worse.
I would look at a different wheel.
Keith
Old 06-23-2011, 08:58 AM   #7
kieth
kieth's Avatar
Spacers get a bad wrap, some folks think they weaken a installation because they "overload the wheel studs. Reality is that if they are high quality they do not weaken anything, When you calculate the load the studs see the only thing that matters is the distance from the outside of the wheel to the location of the studs. A spacer does not change this loading it justs looks different. Kieth
i.e. wide wheel with no spacers-- the lugs and studs see the same loading as a vehicle with spacers and the same width wheel with no or little offset....(late model camaro wheels)
kieth is offline   Reply With Quote
Old 06-23-2011, 06:32 PM   #8
HSkinner
any other reccomendations on another wheel like this?
