06-26-2011, 05:47 AM | #1 |
Six in a row makes it go...
Bed wood interferes with frame rivets?
I'm re-doing the bed on my '67 stepside. The original pine I took out had dents in it from the rivets on top of where the coil springs are.
I'm now putting in some new oak. I'm reluctant to shim the bed upwards. Would grinding the rivets down a little be a better option?
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
06-26-2011, 06:58 AM | #2 |
Re: Bed wood interferes with frame rivets?
I don't believe I'd grind the rivets, as they are what holds the crossa members inside the frame. There are some rubber shims/bumpers that go between the bed cross members and the frame. They're about 2" square. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
06-26-2011, 07:43 AM | #3 |
putting a relief in the wood would b my choice
06-26-2011, 08:19 AM | #4 |
http://www.brotherstrucks.com/prodin...number=BMBP003
These are for a short bed they also have them for long beds.....these will keep the wood off the rivets and space the bed so the body lines are lined up perfect.
00' Z28 ("wifes" car) 92' Mustang w/sbc everything needs a little heart beat 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it |
06-26-2011, 08:28 AM | #5 |
OK. I'll try the shims.
Does anyone know if trucks came from the factory with those shims? Thanks.
06-26-2011, 11:20 AM | #6 |
every truck i took apart had no shims or rubber mounts.
06-26-2011, 11:57 AM | #7 |
That's been my experience also. That's why I don't understand how the shims help line up the body lines. It probably doesn't matter much on a step side...
06-26-2011, 09:32 PM | #8 |
All I know is with out them on my truck the bed is 1/2" low and i put them in and its perfect and quiet.
