![]() Join Date: Apr 2005
I've got a set of Eibach 2" lowering springs on the front of my 68 but would like to lower the truck another 1/2-3/4". How much do I cut off to accomplish this? TIA.
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Grandpa in the rustmobile...
Re: Lowering spring question
1 round = 2 inches 'so ive heard'
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
I think that is for a stock spring. Do you know if that equates to the same thing on a dropped spring?
Moderator
![]() Join Date: May 2007
I would call Eibach and ask them if the spring rate is the same as OEM. If it is, a full coil cut will yield approx. a 2" drop. Have you had a chance to compare them to OEM springs? If they are the same height, the rate would be different, and you would be "guessing" on how much to cut. If they are shorter than OEM, I would think the rate is the same, and you could cut the same amount as OEM.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
put a trade add up maybe? good luck man
67-72 parts collector,…
![]() Join Date: Nov 2002
Trim carefully.
1/2 coil is normally 1" of drop. Cut 1/4 coil and see where you are at.
Keith,
I cut a 1/4 coil and it raised the truck 1/2"!!!! I haven't driven it yet. I assuming it will settle......:\
#8 | |
(There's a "D" shaped loop that it has to be "clocked" to)
I just put it down on all fours to see how it would sit. I still have to finish installing my PB front shock brackets and will make sure then.
#10 | |
R/
Rob, how did it come out?
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
I see how it is rob.... 1 mile away from me and you don't let me know truck stuff is going down? Lol
Why don't you just bag it already? You know you want to lol Posted via Mobile Device
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
Should know tonight!!
anxious to see the outcome. I've read alot about cutting dropped springs, and heard
lots of people say to not do it.. I want to try it myself |
#15 | |
Worked fine.
#16 |
^^thanks for clearing that up, now I know...
#17 |
upper.
#18 |
I think I've got everything "clocked" correctly. Looks like I gained (or lost,
