Old 06-27-2011, 05:28 PM   #1
SpeedyG
55 GMC engine help
I am going to look at a 55 GMC.
its sitting on a camaro front clip. I am wondering can a cummins 24v work with this set up?
or ls/lsx?
tractors are my other hobby and it would be cool to haul/pull a trailer for recovery's
SpeedyG is offline   Reply With Quote
Old 06-27-2011, 07:30 PM   #2
dicer
Re: 55 GMC engine help
It may work with a 1 ton front axle of that year. Its likely much more weight than a small block chevy would be on a camaro front end. Car front ends are NOT truck front ends, they were designed for a much lighter vehicle. People that install them are using the trucks more like cars, not haulling 2000 plus pound loads, if they are they are pushing thier luck.
dicer is offline   Reply With Quote
Old 06-27-2011, 07:36 PM   #3
SpeedyG
hi Dicer, it occurred to me after I posted
not sure what engines I can use on that front clip but doesnt seem like any diesel's will work.
he does have a K 4x4 frame as a roller. I dont know any other options out their to make it a good workable truck. maybe it just needs to be a show car after all.
Old 06-28-2011, 03:00 PM   #4
55metalmonkey
It really depends on if the Camaro clip springs were for a 6 cyl, SBC or BBC,
A BBC weighs aprox 650lbs for a heavy weight with no alum. parts (based on a quick google search), an anorexic cummins diesel weighs a bit more, see chart below.
http://www.adieselengine.com/new_page_1.htm
new engine mounts to take the engine is the easy part but you would need to find much stronger springs for the front and that may be a bit more of a challenge, hauling would be limited slightly because of the added weight in the front, not too big of a deal if it's a 1 ton but since it has a clip I'll assume it's a 1/2 ton which will affect the pay load a fair bit and make it very heavy in the nose.
55metalmonkey is offline   Reply With Quote
Old 07-03-2011, 01:54 PM   #5
Gene Sharp
I have seen a 56 on a dodge pickup frame or clip with
Cummings and 5 spd it is in Winthorse Texas near wichita Falls
Gene Sharp
Gene Sharp is offline   Reply With Quote
