04-02-2003, 07:25 PM | #1 |
help with wiring, truck wont start.
in the middle of a cab swap here.
i just put the cab harness in and connected it to the engine harness at the firewall. hooked up the battery, hooked up the wires to the steering column. hooked up the wires to the ignition. i figured it wasnt going to start like this but now what else needs to be connected in order to get some juice going when i turn the key? |
04-02-2003, 07:33 PM | #2 |
neutral safty switch
04-02-2003, 07:37 PM | #3 | |
04-02-2003, 07:41 PM | #4 |
if you have an automatic tranny its located at the bottom of the steering column and 2heavy gague purple wires go to it
04-02-2003, 07:49 PM | #5 | |
and yes it is an automatic. Last edited by Dropt72Shortbed; 04-02-2003 at 07:52 PM. |
04-02-2003, 07:51 PM | #6 |
heres some pictures of other things i have connected. do these things have to be touching unpainted metal or anything? i dont have them on that tight.
04-02-2003, 07:52 PM | #7 |
one more
04-02-2003, 08:02 PM | #8 |
Seeing as how you don't have a column in the truck, it might be hard to plug in the neutral switch. It is on the steering column under the dash. I think you can take it off and plug in to it and make sure the switch thinks it's in park.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
04-02-2003, 08:07 PM | #9 | |
04-02-2003, 09:05 PM | #10 |
ARRGG kragen tested my battery and said it was bad, so i bought a new one and it still wont start! damnit
im not sure what the problem could be? the only things unplugged were the wires inside the cab as i was swapping cabs. ive hooked up the plug with all the wires from the column, which im assuming is the nuetral saftety switch, i have the column in park... but no cigar? |
04-02-2003, 09:24 PM | #11 |
Resident Curmudgeon
The pic with the wires in your hand show the brake light switch (plug in palm), the backup light switch plug (between fingers), and the neutral/safety switch (center one). Look at your column. At the base (where rubber grommet that seals firewall is) you should see a black switch with sets for electical spades protruding from it. One set is backup, the other is neutral/safety. The ignition system won't work unless the neutral/saftey switch is on. This happens when lever is in park or neutral. You can either plug in the N/S switch to the column, or jump it with a wire for your testing puposes. Either way will complete the circuit. The half-moon plug further up the column is for horn, flashers, signals, etc. Hope this makes sense.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
04-02-2003, 09:37 PM | #12 | |
another thing i realized is the cab isnt grounded. the old cab had no ground straps, i didnt disconnect any and it lifted up fine. the truck was starting and running with that old cab on. i took a set of jumper cables and just tried grounding the new cab to the frame that way. hopefully all it was is this neutral safety switch. ill try tomorrow. |
04-02-2003, 09:39 PM | #13 |
Ground might Help.......
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-02-2003, 11:34 PM | #14 |
Make sure you have the wires all connected where the right front fender at the juction box on the fender. I had one wire missing and had absolutely no power.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
04-02-2003, 11:42 PM | #15 |
"Ochre Ogre"
you can bypass the neutral safety switch. Make a jumper wire and connect the 2 purple wires together. It should be the middle plug that is in your hand in the picture above.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
04-03-2003, 12:29 AM | #16 | |
thanks for all the help guys. |
04-03-2003, 12:35 AM | #17 |
its all about the +6 inches
A bad cab ground won't keep the engine from starting.
I'd just bypass the safety switch for the momen. That will rule out a bad safety switch. |
04-03-2003, 01:48 PM | #18 |
Are you getting any power to the cab?
