06-30-2011, 02:50 PM | #1 |
1968 Chevy C10 Bagged on Wide Whites
Here is my latest project that I picked up about a month ago from a guy in Hopkinton, MA. It had spent most of its life in Missouri driven by an old lady, it still had the Missouri title from '85 when I got it. I have wanted a 67/68 C10 since I was a little kid.
Just turned 100K inline 6 292 with a 4 speed manual trans (pretty much a 3 speed with a granny low 1st). Everything original aside from a couple year old factory matched paint job and the wrong wheels. Its a super solid truck aside from a couple typically spots along the inner rockers. Here are some shots from the day I brought it home. I also picked up an 07 GMC Sierra Z71 back in April down in Virginia after our shop truck puked the trans. 2" front leveling kit on 33" tires. Factory bench freshly recovered still sporting the AM radio. I had to pull the tank to acid etch it and steam pressure wash it to get all the old gunked up gas out. It would run and idle, but fall on its face when you tried to drive it. A friend of mine rebuilt the carb, then we threw a new fuel filter, plugs, wires, air filter. Bed just has some list surface rust, just needs a fresh coat of paint. Non-power drum brakes at all 4 corners with manual steering. |
06-30-2011, 02:51 PM | #2 |
Re: 1968 Chevy C10 Bagged on Wide Whites
Of course I couldn't leave it looking stock for much more than a week. The wheel s are a set of 15" Wheel Vintique smoothies chrome lip, black painted face finished with a set of babymoons. Tires are 235/75/15 Coker Classic 3 1/8" Wide Wide Wall radials. The best part of this truck is the trailing arm rear suspension makes it super easy to bag. We manufacture the front and rear bag brackets in house at my work. The first stage was bagging it on all stock suspension components down to the original shocks. For the air setup I am running a polished aluminum 5 gallon air tank, Slam Specialties SS8 2800lb air bags, Air Zenith OB2 Chrome 200PSI air compressor, Accuair VU4 3/8" manifold to control the air flow through 3/8" airline triggered by an AVS 7 switch billet switchbox. All of the air management is hidden under the factory bed floor (no hole in the bed either) I changed the front shocks out to a pair on Monroes designed for a 50's Chrylser sedan that are a couple inches shorter. Rear bags mounted on the stock trailing arms with Lowrider Depot brackets that i designed using this truck. Polished 5 gallon aluminum 4 port air tank With the addition of a set of Air Ride Technologies tubular lower control arms I was able to get an another 3" of drop out of the front. My intentions when I bought this truck was to obtain this exact stance for the Summer Nationals this week. After an alignment tonight and a quick wash I will be ready to rock. Of course its not low enough, yet.... |
06-30-2011, 03:19 PM | #3 |
Im kinda digging the wide whites.... making me think if I should do this to mine. hmmm
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
06-30-2011, 06:32 PM | #4 |
Nice job!
06-30-2011, 06:44 PM | #5 |
Looks really good
70 SWB STEPSIDE 70 BLAZER 09 challenger |
07-01-2011, 04:21 PM | #6 |
wow, easy i bet...? and wow that is effin CLLEAANNN
07-07-2011, 05:05 PM | #7 |
This how I picture my truck looking after I convert to trailing arms. I love it! Good job!
Posted via Mobile Device |
07-07-2011, 05:15 PM | #8 |
67-72 parts collector,…
SUPER NICE truck.
Everything you have done to it is perfect! Add a set of "conversion"67-70 drop spindles and front disc brakes to get the front a little lower. You can bolt in a set of 1.5" lowering blocks and a bolt-in c-notch to get the rear down that much more. Don't forget a set of rear shock relocators, and an adjustable track bar and you will be set. What city in Missouri did that truck come from?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-07-2011 at 06:34 PM. |
07-07-2011, 05:45 PM | #9 |
that looks sweet
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
07-07-2011, 07:06 PM | #10 |
Love it great look.
07-07-2011, 07:23 PM | #11 |
6>8 Plugless........
Nice find, and sweet transformation!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-19-2011, 07:32 PM | #12 |
B-e-a-u-t-i-f-u-l !!!!!!!!!!!!!
07-20-2011, 02:19 PM | #13 |
I picked up a 1970 Dastun PL521 minitruck over the weekend that will be one of my next projects.
07-20-2011, 02:18 PM | #14 |
Thanks for the compliments guys, I have been driving it for a few weeks now without any problems. Other than the old sixer needs the intake manifold gasket done she is running good.
lolife69 those are pretty much my plans for the next stage of the truck, I want to keep a fairly stock looking bed floor on this truck. -2.5" McGaughy's Drop Spindles -6 Lug 12" Disc Brake Kit, Power Booster w/. master, & Proportioning valve also from McGaughy's -Lowering Blocks with new U-Bolts -2.25" mini bolt in C-Notch -Build an adjustable panhard bar |
07-25-2011, 03:51 PM | #15 |
A couple more pictures from last weekend, she needs to go down a few more inches.
07-25-2011, 04:13 PM | #16 |
Man, your truck looks awesome!
07-25-2011, 09:46 PM | #17 |
what is the color code on the truck if you don't mind me asking?
07-26-2011, 10:07 AM | #18 |
The stock color of this truck is called Saddle w/. White roof.
It was resprayed a couple years ago before I bought it so I am unsure of how close to stock it is. This particular color hides alot similar to silver so its nice not having to wash it everytime I want to take it for a cruise. The paint really pops out at you especially since I threw the white walls on. |
08-02-2011, 03:03 PM | #19 |
With the help of a couple friends I got some under the hood updates from late last week.
-New Gaskets (valve cover, intake/exhaust manifold) -Smog Delete -New Alt Belt -New Fuel Line from pump to carb -Painted the valve cover & air cleaner -Cleaned up some wiring
My 68 C10 Bagged on Wide Whites |
08-03-2011, 01:21 AM | #20 |
Looks nice and shinning! Good work!
08-03-2011, 02:07 AM | #21 |
Nice one! As with the story, conservative w/class added. Great picture!
project: "my happy mess" |
08-03-2011, 02:03 PM | #22 |
'85 Stepside
i like!
08-03-2011, 02:23 PM | #23 |
Looking good!
08-03-2011, 02:33 PM | #24 |
i vote for pulling the grille trim rings off and painting them white to match the bumpers and head light bezels
edit: or leddzepp has a white pair for sale |
08-03-2011, 06:09 PM | #25 |
Very cool!
'68 SWB Fleetside '98 K1500 Silverado |
