Old 07-01-2011, 02:47 AM   #1
jimmyballpeen
jimmyballpeen's Avatar
Turn signals not canceling
Left turn signal stays on after completing turn. Right turn signal cancels like it should after turn. All bulbs are good. I have never had the steering wheel off, Is there a spring in there that broke that is causing this? Its a 72 Blazer Thanks Jim
jimmyballpeen is offline   Reply With Quote
Old 07-01-2011, 02:51 AM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Turn signals not canceling
possible the plastic clip broke off on the cancell switch inside of the steering hub .easy fix
is it a tilt wheel those are a little tricky to work on
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-01-2011, 03:59 AM   #3
jimmyballpeen
No tilt column
Old 07-01-2011, 10:21 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
There are little wire springs that cancel the turn signals, and when they break (the bent ends will snap off), the signals won't cancel. Left spring is a mirror image of the right spring. Hardest part is pulling off the steering wheel -- the springs are easy to replace. My local NAPA carries them, and I suppose any parts house does also.
EDIT: found a pic:
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-01-2011, 12:41 PM   #5
john
member #16
john's Avatar
Heres a pic of them installed.
john is offline   Reply With Quote
Old 07-02-2011, 03:36 AM   #6
jimmyballpeen
You guys are great with the pictures.... Thank you
Old 07-02-2011, 08:22 PM   #7
R.L.
R.L.'s Avatar
My turn signal switch did the same thing, I sprayed a 1/8th can of silicone lube in the turn switch and after a little use mine started working.
R.L. is offline   Reply With Quote
Old 07-04-2011, 04:05 AM   #8
mustardjimmy71
toys'r'us
mustardjimmy71's Avatar
on day in the quiet down town i put on my right turn signal and the spring broke and completed the horn circuit!!! sooo embarassing
71 jimmy bone stock 350 sm465 33x12.5 rallies
79 caprice landau full load crate350 th350 lowered 20"wires
00 f150 reg cab sb 4x4 5.4L
mustardjimmy71 is offline   Reply With Quote
