07-03-2011, 05:29 PM | #1 |
Always a work in progress
Polyurethane bushings/mounts
I am replacing all my rubber suspension components, body mounts, trans, and motor mounts with polyurethane(PST) components. Is this a good or bad idea? Should i just do rubber?
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
07-03-2011, 06:32 PM | #2 |
Re: Polyurethane bushings/mounts
very good idea.....gets rid of the sloppy, worn out, rubber crap...just grease them up good!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
07-03-2011, 10:40 PM | #3 |
IMO dont do the engine and trans mounts. I put them on my old S10 and the vibration at idle was crazy. For a daily driver it was very annoying, esp with the A/C on....
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
07-04-2011, 02:21 PM | #4 |
I think they belong in the sway bar bushings... anywhere else, I think they are overkill. New rubber is probably better,
07-05-2011, 04:58 AM | #5 |
I replaced all my cab mounts with poly on one of the trucks I built, a 78 or 79. It stiffened the truck up considerably, was so harsh I hated it and replaced it with GM rubber after 2 weeks. When I took them back out one of the radiator support mounts was split nearly in two. Rubber makes it ride like a new truck, poly makes it feel like theres no suspension under you. And I'm not particularly picky about a smooth ride. So thumbs down from me.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. |
07-05-2011, 12:44 PM | #6 |
BAD BOW-Silverado XST
Polygraphite bushings work great. I have them on my triuck. Strength of poly and softness of rubber! Use them you like them.
Posted via Mobile Device Posted via Mobile Device |
07-05-2011, 02:35 PM | #7 |
I have the Polygraphite bushings on my upper and lower control arms and swaybar. I dont think it can hurt.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
07-05-2011, 02:52 PM | #8 |
I am going to go polygraphite on the suspension and new rubber mounts on the cab, trans and motor
07-06-2011, 02:37 AM | #9 |
^^^ best idea IMO....
FYI energy suspension's black bushings are polygraphite as well. The red ones are just straight poly.... Posted via Mobile Device
