07-04-2011, 07:32 PM | #1 |
Big Block Monster Stroker
Hey, i need to know if anyone has used a 4.750 stroke crank in a 427 tall deck block to make a 555. A board member told me it was possible and i wanted to know if anyone else has done this. I do know the block will require alot of clearancing. I also know this is quite an ambitious build and its for a later transplant. I also intend to use this for a daily driver. If this is totally imposible i will just go 496
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted 1997 C3500 DRW Ext cab. 454, 4L80E daily driver |
07-04-2011, 11:45 PM | #2 |
Re: Big Block Monster Stroker
Don't know about 4.75 but have seen plenty of 4.50 strokes. Making 525 or so.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
07-05-2011, 12:23 AM | #3 |
I'm going to keep doing my research because if this is possible it will be awesome
07-05-2011, 01:07 AM | #4 |
The biggest I've heard is a 4.5 and some blocks will need a lot of clearancing with possible partial filling.
I too did a lot of research and the tall deck itself does NOT give you any more room than a regular block as far as stroked cranks go. It isn't like the 572 blocks are which has wider bore spacing. Biggest cube I've heard is a 525 and that is with a big overbore on a sonic checked block. Even with a conservative 496 stroker you can use longer rods which are fairly common and the benefit of a 4bolt block Posted via Mobile Device
Project Bad Karma |
07-05-2011, 02:01 AM | #5 |
Dino burner
It's not impossible to fit a 4.75" stroke crankshaft in a factory GM tall deck big block Chevrolet. But, it's not the easiest or least expensive build to do.
The problem with the factory big block Chevrolet blocks is that the main oil passage runs from the back to the front of the block along the oil pan rail. When clearancing the block for the crankshaft, it's very possible that you will grind into the oil passage. Also, the coolant passages are at risk of being compromised when grinding the block for clearance. The oil passage can sometimes be repaired by pressing an appropriately sized thin-wall tube into the oil galley. If you strike water, however, the block will either need to be welded by someone experienced with welding cast iron, or it must be brazed, or it must be fixed using something like a 2-part engine epoxy. A specially clearanced oil pan will also be required to clear that size of a stroke. Understandably, steel connecting rods are preferred, and really, are the only option -- aluminum connecting rods simply require too much clearancing. If you plan on going this direction, work closely with your crankshaft, connecting rod and piston manufacturer(s) as there are many dimensions that must be considered. Using a crankshaft with cam-shaped counterweights will help, as will a rod that is forged with as small of a 'big end' as is possible. Your connecting rod length will be dictated in part by what compression height piston you want to run and the shape of the crankshaft eccentrics your crankshaft manufacturer can supply. For example, if you want to run a 6.70" connecting rod with the 4.75" stroke, the compression height of the pistons will need to be 1.12" which is very short. With such short compression height pistons, you will need to deal with the piston pin bore intersecting with the oil ring groove. It's good that you're planning far in advance because as you can see, there's more to it than just grinding on the block |
07-05-2011, 01:18 PM | #6 |
At the body shop.
Get a dart block. Go 598
" That didnt make it any newer " " Dont antique the equipment " |
07-05-2011, 02:07 PM | #8 |
Resident of Here
Get a 572. Solved!
This should help: http://answers.yahoo.com/question/in...5173832AAG5PNe http://www.popularhotrodding.com/tec...ous_plate.html
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
07-05-2011, 02:56 PM | #9 |
I know the rod to use is a billet steel rod and I think its 6.5.. the guy I'm getting the crank from has six rods for sale and i will pick them up too . im going to keep looking into it.
07-05-2011, 03:13 PM | #10 |
Resident of Here
The Edelbrock/Musi 555 uses Scat 4340 steel rods, why would you want to use aluminum? It melts at a lower temperature.
07-05-2011, 03:57 PM | #11 |
I talked to my engine builder and he said its very possible and has done a few of them but not as daily drivers and the ones he built did NOT have block hard in them. We r going to do some experiments to see what problem I may run into. I do know the block will have to be CNC'd to keep flaws down to a minimum.
07-05-2011, 05:07 PM | #12 |
I agree buy a dart block. If you are gonna try to race this motor in a truck go short deck 540 or so with aluminum heads. The weight needs to be kept to a minimum on the nose if you want it to hook.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
07-05-2011, 05:34 PM | #13 |
$2-400 for the block (unless already have it) then $12-1500 for the machining to clear the crank and to clear the rods for the cam and what not. You will be well over $1500 at a minimum for this block which, IMO is not worth putting the money into when you can find deals on Dart or other blocks for $1800-2000 all day. Then again, its your money and your decision.
07-05-2011, 05:40 PM | #14 |
I got a really good deal on a bowtie block and could have bought a dart for about what I have in this one now. The dart requires so much less machine work and its much stronger. Sunset Racecraft quoted me a little over something like 2200 ready to assemble.
07-05-2011, 08:20 PM | #15 |
Registered Truck Offender
What are the t /s and outlaw guys using to build these 600" BBC's?
My machinist had a 60x" alcohol injected BBC someone put a $10k deposit on, lost his job and bolted. He needed another $8k to pay it off. I was like hmmm maybe I should If I ever go BBC,,,, it will be somethng like that. 900 pound feet of torque from 4000-6800!!! You don't even have to beat up on these things!!!
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
07-05-2011, 08:51 PM | #16 |
i am starting to lean towards a dart or merlin block so maybe ill go bigger
07-06-2011, 08:59 AM | #17 |
Don't buy the merlin. It takes much more machine work to make it right. Buy the dart in a steel block or a brodix if you go aluminum. I studied these hard when I was working on my motor.
07-06-2011, 04:14 PM | #18 |
Thanks for the heads up im definitly going to look into a dart
07-06-2011, 06:37 PM | #19 |
598 Woohoo.... Here we go.
07-06-2011, 07:01 PM | #20 |
Im thinking more along the lines of 632
07-07-2011, 12:13 AM | #21 |
Are you ready to spend $4k+ on heads then new intake/dist/possibly change your brake booster, Headers..... List goes on for a tall deck. You can do a short deck for a lot less. Complete 632 will be over $15k alone then engine bay changes. 598 can be under $10k depending on what you reuse and no engine bay changes. 34CI isn't worth that much to me. you can make that up with some compression or a more radical cam/head combo.
07-06-2011, 10:01 PM | #22 |
Dino burner
07-06-2011, 10:05 PM | #23 | |
I told you I did my Homework!!!!!!!!!!!!!!!!!!!!!!!!!!!!
07-07-2011, 09:29 AM | #24 |
Resident of Here
I have a question, why do you want to go 555? Why not add a turbo or supercharger to make good power?
07-07-2011, 09:33 AM | #25 | |
Sometimes the point is to have a big engine, just for the sake of having it
Project Bad Karma |
