I need help again!
You guys seem to know how to fix all of my problems... so here goes..
I left the lights on all day at work, all 8 hours. Battery was dead, lights didnt work after that. they blinked once and stayed off.. I replaced the switch and now the lights blink on and off but only on bright and dim does it occasionally... I checked power to the switch, and its constant good power. Can anyone help ? http://www.youtube.com/watch?feature...&v=sWTtUGsry2w
![]() ![]() ![]() ![]() Last edited by Mrtn15; 07-05-2011 at 06:23 PM. |
Re: I need help again!
You left the lights on 8 hrs, what did you do to get it started?
John 82 Chevy Silverado 350ci/TH350 ![]() |
#3 | |
![]() ![]() ![]() ![]() Last edited by Mrtn15; 07-05-2011 at 07:00 PM. |
You need to be carefull when charging batterys like that, people have blown up bats and got acid all over themselvse. You said you changed the light switch, was it new or used? When you changed it did you see any burned wires on the plug for the light switch?
#5 | |
The switch is NEW.. And there were no burned wires.. That was confusing for me too..
The battery is very close to the head light plug ends on the right side of the truck, did you damage any wires or plug ends wile you were charging/jumping your battery?
Thats definatly a problem. If you cant replace it, tape it up real good. Let me know how it turns out.
#8 | |
how could I replace it ? does that wire pull out ? if so, I could cut it back and just re do it ? or do you have to buy a new plug ?
You can tape up the single wire for now and be ok.
You can go to the junk yard or auto parts store and get a replacement plug cheap. They will come with about 4in of wire so you have enough to connect. Your damaged wire is to close to the plug to be fixed properly.
#10 | |
Your welcome bro, dont say that to loud you might ruin my bad reputation LOL.
haha, I'm about to post another pist reguarding the lights inside my gauge cluster.. The only lights that work are the ones that light up the gauges and my blinkers.. no engine light, no Dim\Bright headlight light, or anything else
Thats easy, remove your gauge bezel then remove your gauge cluster, and change all the bulbs (EVERY LAST ONE OF THEM! GOT IT). The bulbs in your dash are the 194 push in just like your side marker lights. should be about 10 or 12 of them.
Could it not be wiring ?
#15 |
#16 |
I doubt it, there is a printed plastic circut board behind your gauge cluster that powers every light you are having a problem with.
#17 |
oh, cool ! Thanks a lot man!..You have helped me a lot!
#18 |
yeah I replaced all the light bulbs on that thing a couple weeks ago.
Made it feel all new when I turned the lights on. |
#19 |
haha, well.. I want to do this to my lights also! I hope to do it pretty soon! Thanks guys! I have never even seen a cluster with ALL the lights on, could some makes this happen for me ?
#20 |
Go back to other thread for more detailes.
#21 |
its pretty easy.
I would help you but Im in North Carolina now. |
#22 |
lol yeah, I just googled it! It looks pretty cool. I might find some little l.e.d bulbs to put into there.
#23 |
That would be so much more work than just popping in a few bulbs.
Its pretty bright when its all on. If its still not bright enough for you, paint the reflectors behind the gauges silver or spray chrome. |
#24 |
ooooh, That's a good idea! I'm sure it will be bright enough! Thanks again man! I will post a thread with pics of me changing, and painting if necessary!
#25 |
Actually white is even better than silver. I just did mine when I cobbled together a tach cluster and it made a huge difference. Its actually bright enough to see at night now.
