Old 07-05-2011, 10:29 PM   #1
cwilkie
Chance
cwilkie's Avatar
What heads are better for towing and plowing.
I am undecided on what type of heads to use when a 402bb & th400 are installed in my 1972 3/4 4x4. I plan on using the truck to do some light hauling, towing, and snow plowing. There will be occasional trips to the hardware store that that is about 120 miles away so I would like it to be drivable.
I have a set of casting number 292 open chamber heads and a set of casting number 063 closed chamber heads. I won't be hot rodding around but I do want some torque if needed.
Since a new 3/4 4x4 is around $40,000 I figure I would just spend a few thousand on upgrading mine and actaully own it instead of the bank owning it like they would a new one.
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 07-05-2011, 10:37 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: What heads are better for towing and plowing.
How much do ya wanna spend?
Are you particular, steel vs aluminum?
Do you wanna try to keep your stock valve covers/intake manifold?..
John
1999 Toyota Tacoma 4x4
Old 07-06-2011, 11:57 PM   #3
cwilkie
Chance
cwilkie's Avatar
I want to stick with the cast heads. Since I cannot afford more parts I need to choose either casting number 292 open chamber heads and a set of casting number 063 closed chamber heads. That is all I have for a budget.
BB 396 w/TH400
BB 496 w/TH400
Old 07-07-2011, 12:08 AM   #4
67_C-30
I have a radical idea!
67_C-30's Avatar
If you are going to leave the short block as is, the 063's are going to make about 9.5 : 1, and will make a lot more power and torque. The open chamber 290's are going to make closer to 8.0 : 1 with .039" composite head gaskets.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 07-07-2011, 07:24 AM   #5
Yeah,I'd say use the 063s and save the open chambers for if & when you build the motor up.
