07-06-2011, 08:31 PM | #1 |
67 gmc body parts, small letter tailgate, grille and more
getting ready to change over to chevy body parts. figured i might as well list these here to check interest. i am looking at this weekend to switch over the parts. will pull before if sold locally. here`s what i have
1. 67 gmc grille with headlight bezels. this is a painted grille. nice condition. good be chromed if wanted. $150 2. 67 gmc core support with 4 bulb setup. will include spare 4 buckets and trim rings. has the usual bad spot under battery. easy fix for someone wanting original stuff. also has 4 new bulbs installed. $80 3. 67-68 chevy/gmc hood. really nice condition. $50 has 1 hole in it see pics below. 5. 67 8 foot fleetside bed sides. outside is in good condition inside lip needs some work. $125 drivers $75 pass or $175 for the set pass side has 2 small rust holes behind the wheel well drivers looked good. 6. steel floor header panel. really straight. $70 couple of the bolt holes were cut to get bolts out(not by me). still nice panel 7. cowl panel $15 in need of inner fenders or a soft tonneau cover if anyones interested in trading for something. Last edited by 2002yanks; 07-29-2011 at 09:44 PM. |
07-06-2011, 08:32 PM | #2 |
Re: 67 gmc body parts
pass bedside |
07-06-2011, 08:44 PM | #3 |
Vintage 4x4s
Re: 67 gmc body parts, small letter tailgate, grille and more
interested in pics of tailgate inside if you would consider shipping. also curoius why you are changing bedsides and cowl to go chevy?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
07-06-2011, 09:01 PM | #4 | |
got a no antenna hole cowl to put on and got a new bed with an actual floor in it. mine has a makeshift wood floor in it. the floor supports would need replacing on mine. |
07-06-2011, 09:24 PM | #5 |
just took these(getting dark so thats all i can get for tonight. if its not what you want let me know and i`ll get some tomorrow afternoon. shipping is possible(wont be cheap). would go down to $450 without the hardware(i could use the handle and long bars inside and end latch for my new gate). just throwing that out there.
07-06-2011, 11:39 PM | #6 |
Vintage 4x4s
Thanks. If you could get some pics of the whole bedside and any dents inside or out not pictured already that would be good. I see so many banged up from stuff rolling around in the bed. Also is greyhound an option for you? If so, price to Mpls area.
07-07-2011, 12:48 AM | #7 |
will do. never shipped greyhound, but can if needed(will need help figuring it out). have a bus stop about 40 minutes away.
07-07-2011, 04:27 PM | #8 |
ok lets see if this works for you. the bed is just about dent free that i see. i dont think they ever hauled anything. no clue why the original bed floor rotted out. sucks it did or i would keep this one. the inside lip needs work and there are 2 small holes in the inside panels. 1 in front of the wheel well on the drivers side, and 1 on the pass side near the rear of the panel. the front panel is nice.
07-07-2011, 09:53 PM | #9 |
Vintage 4x4s
Sorry I meant to say pics of the "bed side" of the tailgate. Just want to know about the tailgate and any dents, filler, previous repair, or other issues it has.
07-07-2011, 10:39 PM | #10 |
sorry for that. i saw bedside and was thinking the side panels. dont know why when you asked about the tailgate. i will figure out someway to show the "dent" i was talking about. think thats the only issue. will get some pics of both sides. if i can get some time i will take it off and get a bottom pic too.
07-08-2011, 10:49 AM | #11 |
interested in the hood if there isn't any rust. Where is Auburn located?
07-08-2011, 11:37 AM | #12 |
07-08-2011, 03:21 PM | #13 |
My son lives near Rochester, so that seems to be the answer for pick up. My main concern is rust, as we both know we live in the rust belt. Pics would be great, but I want you to know I will be leaving for vacation on Sat. for a weeks vacation, just in case I don't respond to your thread or PM's. Not sure if I will internet access, maybe on my phone
07-08-2011, 04:17 PM | #14 |
Vintage 4x4s
Thanks for the pics and checking that out. Due to what you've found on the hood, I'm a tad nervous the PO may have covered some things up on the tailgate with filler. I'm definitely still interested but need more assurance. Maybe test all areas with a magnet or maybe theres another way to know for sure?
07-08-2011, 04:21 PM | #15 |
no problem. like i said i saw the spot on the hood and it looked like a paint edge(were it wasnt sanded good). the tailgate only had that 1 spot with the same look. but wehen i sanded it went away(can see bare metal). only had a few 220 grit sandpapers so i couldnt do it all. will go out and check with a magnet. i have a small lightweight magnet on the bottom of a mirror.
07-08-2011, 04:30 PM | #16 |
just did the magnet trick. sticks anywhere i put it on gate. just to make sure i tried it on my cab corners and it wont stick(cab corners have alot of bondo in them).
07-08-2011, 08:55 PM | #17 |
I think I'll pass for now, but thank you very much for being straight forward!
07-08-2011, 08:59 PM | #18 |
no problem. not being able to see it in person i wanted to look it over with a fine tooth comb. sucks that was there cause its the only thing wrong with it. i might practice my repair skills on this after i change over. if it doesnt sell first.
07-09-2011, 06:32 PM | #19 |
Vintage 4x4s
I would do 475 shipped on the gate. Should be able to do greyhound to keep shipping reasonable.
07-09-2011, 10:51 PM | #20 |
let me look into shipping tomorrow. i need to get a weight. as far as packing it should i build a box for it? i could do a 2*4 frame with plywood top and bottom. hows that sound? are you ok with me keeping the handle and harware for it(seeing i`m going even alittle lower on price i think its fair)?
07-10-2011, 12:34 AM | #21 |
Vintage 4x4s
Sounds good.
07-10-2011, 01:52 PM | #22 |
got the handle and stuff off and weighed it. was 55 pounds or so. so by time i add packaging it will be 85 or so. checked greyhound and it was 112 to ship. checked ups and it was 83.45 plus i would have to get some plywood(dont have any right now). so thats another 25 or so. if you could do $500 total that would work for me. doing it through ups also allows for full $500 insurance were as greyhound was $300 max(plus its a 45 min drive to drop off for me). i feel safer with ups(never used greyhound). you will not be disappointed with this gate(if it have chevrolet on the back it wouldnt be going anywhere). the one i have for my new bed is not as nice(it has a few small dents and trim holes). let me know what you think.
i can do paypal or money orders. for paypal i just ask that its sent as a gift so i dont get hit with the 3% fees(or add the 3% to the total to cover fees). or pm me for address to send money order. either way is fine. paypal is kmalone02@verizon.net |
07-10-2011, 02:25 PM | #23 |
Vintage 4x4s
Did you verify there is no rust on the bottom edge?
07-10-2011, 02:27 PM | #24 |
07-10-2011, 02:41 PM | #25 |
ttt
