Ford rearend in a 65 c10
Just wondering if anybody has put a ford 9 inch or even an 8.8 rearend in these trucks and how hard or labor intensive it is and is it worth it if I am building it to be a weekend toy/ daily driver
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
60-66 Nut
Re: Ford rearend in a 65 c10
Here's one build with an 8.8
http://www.67-72chevytrucks.com/vboa...d.php?t=385486 IMO there's nothing wrong with the truck 12 bolt for your intended use.
![]() Join Date: Jul 2009
Ford 9" is not a problem. You can narrow it or look for one that is the same width as your stocker. You can get mounting pads from someone like ECE.
Im running an 8.8 and it fits perfectly. Disk brakes, limited slip and was 61" wms to wms. All that was needed was the u bolt perches welded in. A 12 bolt would work fine too but I used what I had.
It's Better With Nitro
As mentioned, a Ford 9-inch is no problem. I had an extra sheetmetal housing laying around for my build, but the concept is the same.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Ya I do agree with the fact that there is nothing wrong with a 12 bolt but I just happened across a couple of good nine inchers for really cheap and my 12 bolt is trashed unless I want to spend a load of money on it
