Old 07-07-2011, 08:26 PM   #1
CABAN40CAL
Need help identifying my small block v8
I'VE BEEN CHECKING A FEW SITES AND WAS UNABLE TO FIND OUT WHAT VEHICLE AND YEAR THE ENGINE CAME OUT OF. THE REAR BLOCK DRIVER SIDE CASTING NUMBER IS 3970010. FRONT PASSENGER BLOCK STAMP SUFFIX ID NUMBER IS 13L177825, V0220CKD. I NEED TO FIND OUT IF IT'S 350 OR 327 AND WHAT YEAR AND TRUCK IT CAME OUT OF.
IT'S CURRENTLY IN MY SONS 64 C10 SHORT SIDESTEP WE ARE RESTORING.
THANK YOU FOR YOUR HELP:chevy.
CABAN40CAL is offline   Reply With Quote
Old 07-07-2011, 08:54 PM   #2
steverino66
Re: Need help identifying my small block v8
350 - 1969-'80, could be 2- or 4-bolt:
www.mortec.com
steverino66 is offline   Reply With Quote
Old 07-07-2011, 08:58 PM   #3
steverino66
I used Mortec on mine 5 years ago, same number, but just tried it and got the endless internet runaround. Here's another site with the info:
http://www.ajgeneral.com/sbc_block_casting_numbers/
Old 07-08-2011, 12:07 AM   #4
Captainfab
60-66 Nut
Looking here at your suffix code CKD, it is a 350
http://www.nastyz28.com/gm-chevy-cod...s-suffix-2.php
To find exactly what year it is, you will need to find the date code on the back of the block. I believe it is on the passenger side.
Old 07-09-2011, 03:10 PM   #5
CABAN40CAL
Cool Re: Need help identifying my small block v8
Thanks for the info. So it may be a 350. Now I just have one last question. I've been told that this may be a high nickle 350 block since the numbers behind the block passenger side list the "509". From what I've been told some of those 350 "509" sbc where made with higher nickle. Is it?
REAR BLOCK PASSANGER SIDE:
H20 010
509 020
REAR BLOCK DRIVER SIDE CASTING NUMBER:
3970010
PASSENGER BLOCK STAMP SUFFIX ID NUMBER:
13L177825, V0220CKD
Old 07-09-2011, 03:39 PM   #6
JasonWynn88
Yeah that is a 350, if iam not mistaken the (010) is ten percent more tin and the (020) is twenty percent more nickel. That means that those percentages were put into the casting of the block when it was made. It makes its a more desirable block and alot more stronger and better to be able to withstand heat. The 3970010 was also a earlier 302 block but the VIN number on the front of the block will be able to tell you exactly what it is.
JasonWynn88 is offline   Reply With Quote
Old 07-10-2011, 01:06 AM   #7
Captainfab
60-66 Nut
Yes the 010 and the 020 is indicative of the tin and nickel contend of the block. But I'm not understandinf some of what you posted of the passenger side casting numbers. The H20 could be part of the casting date, as in August 20th. You might take another look.
H20 010
509 020
3970010
13L177825, V0220CKD
Old 07-10-2011, 04:25 AM   #8
63sbssbbw
UCA63
63sbssbbw's Avatar
I thought i read somewhere that the 010 and 020 were stamped(not cast) into the block behind the timing cover,one on each side of the crank....?
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 07-11-2011, 12:47 AM   #9
Captainfab
60-66 Nut
They are cast into the block
T
Old 07-11-2011, 05:11 AM   #10
63sbssbbw
UCA63
63sbssbbw's Avatar
OK ,good to know Cptn,thanks
T
member#7816
'61 GMC in progress
