Old 07-09-2011, 11:03 AM   #1
Heartbeat66
Heartbeat66's Avatar
gas gauge sending wire help.
Hello all, I have a 1966 chevy c10 with a gas tank behind the seat. I am trying to figure out where I connect the brown gas gauge wire coming off the tank. Do I connect it to the fuse block where it says "gas ext"? Thanks
Heartbeat66 is offline   Reply With Quote
Old 07-09-2011, 11:08 AM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: gas gauge sending wire help.
that wire should go to the guage. the guage will get its power from the fuse block
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-09-2011, 11:18 AM   #3
willyp
willyp's Avatar
61 is correct, just want to add there are 2 terminal posts on the back of the fuel gauge. that brown wire from the sending unit connects to the terminal post closest to the radio.
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 07-09-2011, 06:04 PM   #4
TR65
TR65's Avatar
Heartbeat,
The guys are right about how it works. But the brown wire does go to the fuse block where it is marked gas gage. It is not a power connection, just a junction. There is a wire on the other side that goes up to the gage. (According to the shop manual and how my truck is wired). Assumes you are using the stock harness etc.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 07-09-2011, 06:15 PM   #5
Heartbeat66
Yes I bought original wiring. I also bought a wiring diagram for it, but it is hard to understand exactly. I think I found the correct spot i'll post after follow your guys advice. Thanks for the help.
Old 09-25-2011, 09:16 PM   #6
Sneaux
Sneaux's Avatar
Did you get it figured out? Im in the same boat with the fuel gauge not working. The previous owner cut the brown sending wire from the tank and there was no wires connected to the back of the fuel gauge.
Sneaux is offline   Reply With Quote
Old 09-25-2011, 11:01 PM   #7
overtimeracing
overtimeracing's Avatar
The brown wire on my 63 runs from the tank to the fuse box. FYI... Thx...Kevin
overtimeracing is offline   Reply With Quote
Old 09-26-2011, 09:45 AM   #8
Heartbeat66
Thanks, I have all the gauges working so far. I just need to install the copper oil pressure line and everything will work.
