Alternator install help
The water pump is in thank you very much! The alternator was bad so I have a new one I put in however....as it is my first time installing one I have an extra hot wire coming directly from battery that I did not re install( stupid newbie mistake) and cannot figure out where it bolts on. Help?
Posted via Mobile Device |
Re: Alternator install help
The wire you speak of, is it the negative battery cable?
John 82 Chevy Silverado 350ci/TH350 ![]() |
Nope looks like it is coming from positive side
Can you post a pic?
Chevys Kick A$$
What do you mean by extra? Do you already have the one power hooked to the starter and the one to the back of the alternator?
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Here is the picture of what I have left. I have the 2 prongs plugged in and the wire under the nut. This is what is left...I am a newbie at this but I do not remember undoing this wire...but I must have...
So thats the wire that goes to the positive battery post? Is it built into the positive battery cable? Got a pic of the other end of that wire?
hope this helps....it is EXTREMELY sunny and hot outside so the camera kept fogging over!
looks to me like its the ground that goes to the frame.
well if it helps...when i "accidentally found it" and grounded it out...sparks flew and the motor about died out.
Gentleman Jim owner x2
![]() Join Date: Oct 2010
Isn't that your charging wire? If it is, it goes on the little stud with a nut on the back of your alternator.
1975 GMC Gentleman Jim #1 -357 / 700r4 1975 GMC Gentleman Jim #2 -350 / TH350 |
Where does the wire that you already hooked up go to? I'm guessing either to the starter or to the fuse block. Either way, you should just hook up both wires under the stud/nut on the alternator.
If your alternate is working and charging your battery with no issues, tape it off and zip tie it secure and you should be fine. My bat cables don't even have that wire.
#15 |
18 Till I Die
That is the charge wire for the back of the Altenator. It is a must! I would hook it up and find out where the other wire leads off to. Might be a Previous owner hook up for something else.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
#16 |
#17 |
18 Till I Die
Yes. I guessin someone ran another wire to the stud for a power sorce for something? Disconnect it and see what doesnt work?
#18 |
it worked and we are back running again with new alternator and water pump. Thank you..we are reading out right above 13 on the battery meter and not getting over half way on heat....GREAT NEWS!!
#19 |
Chevys Kick A$$
Nice that's good to hear glad you finally got it fixed. Now got drive the truck and get out and enjoy it.
