85 K5 FaceLift!?!?
Couldn't find info elsewhere - so here goes. I would like to take the doors and nose off my '85, and replace them with 73-80 parts. What am I looking at for problems??? Trim lines? Wiper motor/connectors replacement? Any and all input is appreciated..... Thanks
1994 C1500 rclb 1988 C1500 rclb 1969 ES5500 B E A S T 1983 C10 'farm truck' 1976 K20 Suburban 1984 K10 Suburban 1981 Jeep CJ5/350 Vortec 1941 Dodge WC18 Ambulance 2000 GMC Bus (parts warehouse) |
Re: 85 K5 FaceLift!?!?
Not completely up to speed on K5's, but I do know that earlier model K's had a removable top that went all the way to the windshield, and the later models stopped just behind the front seats. That would definitely make the door different, as well as the whole body. Not sure what year they changed this design, and I know you can cut later model doors off to use on the earlier models, but it would be very different trying to go the opposite way.
Now the front clip should interchange rather easily, you'll just need the core support and body parts, with the bumper, to do the swap. Not sure on the trim either, but the body lines should match up so just yank the trim off the whole thing and fill the holes.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
Thanks Psycho71,
I'd like to own one of the full convertibles someday. I've got parts up the wahzoo (never a bad thing) so replacing the rusted panels won't cost me much. My friend owns a Body Shop and cuts me a real break on doing the rocker panels, wheel arches and tail pan work. Having two '74 trucks, I wanted to 'complete the look' with the K5.
I don't think the doors are different on the outside. Probably no need to swap unless the existing ones are damaged or rusted.
The front clip interchanges easily too. Most later models had dual headlights, while the earlier ones had single. So you may need to do some minor wiring changes. I prefer to run individual solenoids for each light anyway, so would modify the headlight wiring anyway. Seems like a lot of work to make the change if all you get out of it is a styling change. I'm an old guy now -- but I remember my younger days when I'd such a venture on a whim. So I say, if you want to do it, why not? |
When switching to dual headlights from singles on my suburban the wiring was exactly the same a 2 piece plugin block clipped together and held in by an 8mm bolt i think not sure if it changes for blazers
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
I know the pieces fit
The cowl/wipers are different on the 70's trucks, not sure what year the change was made.
laying low
![]() Join Date: Mar 2001
i think that would be '81 for the change.
I put a 1980 clip and doors on my 1988, the top bolts in the fenders [by the hood hinges] don't line up, so they didn't go in, I recommed using the '70's bumper because the '80's bumper will crunch into the fenders [or you could shave the top corners of the bumper off] and the body mounts have to be combined in an odd way I can't remember. Also have to change out the windshield wiper assembly, I left the windshield washer in it but hooked the plumbing into the hood, had to rig my 2wd 1986 C-10 aluminum rad into the support BUT they do make the right clamp-downs for it, had to use the 1980 radaitor overflow, and I'll have to use the '73-'80 air conditioning condensing coil and line set for the A/C.
At least that's what all I went through. Totally worth it.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
