07-11-2011, 07:39 PM | #1 |
spark plugs question. confused
I have a 82 silverado with a 350. Has 492 heads and 9.5-1 compression. I swapped plugs. Went from r45ts to r43ts because of advice from a mechanic. Problem is now my idle rpms are lower and there is power loss. Do you have to advance timing with a cooler plug? Should I switch back to the hotter plug? Thanks in advance.
Posted via Mobile Device |
07-11-2011, 08:31 PM | #2 |
BAD BOW-Silverado XST
Re: spark plugs question. confused
More compression = LESS gap. Less gap is needed to overcome higher compression pressure resistance. Have you tried using a different gap? What type of ignition do you have on it?
07-11-2011, 10:40 PM | #3 |
Hei distributor. Gap is .35. Guess I should have set it at .45?
