MOTORHEAD!
15x12 rally wheel?
Will they fit on a stock lwb? And if so, what backspacing is ideal?
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
Always a work in progress
Re: 15x12 rally wheel?
Please let me know where you have found them.
I would say 6-7" of BS should work depending on tire size. I am looking into running a 15x12 but haven't found a 12" rally. The tire I plan to run is 29x15r15 MT Sportsman S/R. You might have to modify your tub if you want a really big tire
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
Badass
My 10 inch wide rim and tire combo are the limit IMO. They rub the inner tubs on hard turns. And yea where did you find this 12" wide rally?
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
MOTORHEAD!
I am attempting to order them through Wheelmaster Classics in Calgary... He's a distributor for Wheel Vintiques... He is getting back to me tomorrow with their answer as far as "will they do it". He cannot see why not as they offer a 15" corvette ralley in 10,12,and 14" and they both share the same diameter center section of the wheel... Currently with my 15x10"/5"bs with 295/50/15's there is about 1 3/4" of space between tire and wheel well. That being said, if I am able to order a custom backspace, would 6" be ideal? I want to run the MT S/R's as well, 30/12/15 or wider if possible..
MOTORHEAD!
@ 3r!c84, what tire combo are you using?
Badass
315/35/17 not a 15 inch rim but still 10 inch wide. im running the max width i can fit
btw are you lowerd? ![]()
MOTORHEAD!
No I'm stock height right now. Those tires look sick!
Badass
first set of tires. same size. but they are 12inch wide. so you might get lucky
MOTORHEAD!
Sorry, what size are the tires in your last post?
Badass
Same size as in the top pic with the truck, 315/35/17
![]() Join Date: Dec 1999
Top Banana has two setting in the show room but not for sure what the back space is.
MOTORHEAD!
Confirmed!!! I can get 15x12 or 15x14 rally wheels!!! I guess wheel vintiques is willing to make them! They are just under $240 a piece!
if you get them post pics
Edited by staff |
MOTORHEAD!
Can't decide on proper backspacing for a stock height lwb... Ordering hinges on that...
#15 |
MOTORHEAD!
Anyone running a 12" wide wheel on a non lowered truck? Backspacing PULEASE!!!
#16 |
67-72 parts collector,…
![]() Join Date: Nov 2002
15x8 wheel has a 4" backspace.
15x12 wheel will need an 8" backspace for the outer edge of the rim to end up in the same location as a stock wheel. This will require mini-tubbing the bed. (A 7" backspace would probably work also)
#17 |
15x12 with 7 inch backspacing. Bed floor cut to the frame.
#18 |
resident wrencher
I put 31x 13.5 `15s on my lwb but i also had 15x8.5 inch wheels i had no rubbing issures with that size tire and looked *****en i dont know the backspace THEY PRETTY MUCH STAYED IN THE STOCK LOCATION THO
#19 |
Ratrod, what size tires are those?
#20 |
#21 |
MOTORHEAD!
wow. those look bloody awesome!!!!
