Old 04-04-2003, 07:23 PM   #1
Hard_Core_Hick
Service Engine light
I was woundering if its me or are ther other 87 c10 and r10s out there with the same problem with the service engine soon light coming on and off , i have tried every thing i can think of and even replaced the parts i thought they were.
and another question , might sound dumb but is the R10 model chev or Gm
I need a 454 4 barrel and dad wont let me get one
Hard_Core_Hick is offline   Reply With Quote
Old 04-04-2003, 07:59 PM   #2
RockHQ
ROCKET POWER!
RockHQ's Avatar
R10=1987 Chevy C-10 pick-up, 1987-1991 Chevy C-10 Suburban/Blazer
R30=1987-1991 1-ton crewcabs and duallys
V10=1987 Chevy K-10 pick-up, 1987-1991 Chevy K-10 Suburban/Blazer
V20=1987-1991 K-20 Chevy Suburban.
Essentially, GM just renamed the old style models because 1988 the new body style pick-ups were introduced. Crewcabs, duallys, blazers and suburbans were of the old body style to 1991.
Correct me if i missed something?
-Axle
[edit]
What do you mean Chevy or GM?
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 04-04-2003, 11:25 PM   #3
Cole's 87
Cole's 87's Avatar
If your truck is a 87 then its fuel injected most of the check engine light would fall under emissions. before I pulled out the 305tbi the light would just about stay on after a new MAP sensor , EGR valve, vacume lines. There is a trick to use a paper clip in the data port under the dash this will get the check engine light to flash the codes. Mabey someone else on here can tell you about the paper clip trick.
Cole's 87 is offline   Reply With Quote
Old 04-05-2003, 12:15 AM   #4
RockHQ
ROCKET POWER!
RockHQ's Avatar
the ALDL (Assembly Line Data Link) connector is indeed below the dash on the driver's side, you connect the upper right two pins to get the SES light to flash codes.
Looking at the connector, the pins are:
__________
|F E D C B A|
|G H J K L M|
Pin A is ground, pin B is the diagnostic test terminal. Use a paper clip to connect these.
-Axle
