Pro Comp intake coolant crossover
The coolant crossover is the only solution i can find for the four holes being on each of the corners of this intake manifold I just purchessed. I am doing the vortec head swap and this is the manifold I plan on going with. Did I make a mistake when buying this?
Can I just plug three of these holes and use the other for the temp sending unit? And what about the oil pressure sending unit, is it in the manifold or the block? Because I do not see a place to put the unit. Thanks! |
Re: Pro Comp intake coolant crossover
There is also a tapped hole that goes into the port, between the intake and the dist. hole. Whats that for?
Old Heap Driver
Vacuum source.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
On mine I plugged the rears and I believe my vacuum "tree" went in behind the carb flange.
Fronts, whatever you want. I believe I plugged one and used the other for a temp sender Sending unit is behind the intake, on the block.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
![]() Join Date: Jul 2010
oil pressure sending unit should be @ tha back of tha block behind tha dizzy
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
Thanks for all the replys guys, just did a distributor swap and found the oil sending unit. I was just making sure i did not waste my money on this manifold.
Thanks again! |
