07-21-2011, 03:19 PM | #1 |
70 chevy cab roof lights
Is it rare to have the lights on the roof of the cab ? Some one told me that was rare to see ??
07-21-2011, 03:23 PM | #2 |
Re: 70 chevy cab roof lights
I also think they were more common on C30s correct me if im wrong.
07-21-2011, 03:31 PM | #3 |
The truck is a 1970 c10 4x4
07-21-2011, 05:50 PM | #4 |
Roadtrip!
I have a 70 and 71 both with cab lights. Both 1/2 ton, both 4x4. I don't think rare is the right word.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
07-21-2011, 08:15 PM | #5 |
its all about the +6 inches
uncommon back in the day, considerably more uncommon today.
1/2 ton is the least common, and one ton is quite common (being it was required on anything with dual rear wheels). |
07-21-2011, 08:33 PM | #6 |
The 1 ton has raised dimples for the lights. My service manual says Subs and Panels had tear drop lights installed on flat roof panel.
I am still trying to figure out where the ICC harness that comes down the left pillar poat hooks up. ???
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
07-21-2011, 10:57 PM | #7 |
all pickups with the clearance/ID lights on top had the raised pads (69 - 72)
The wire hooks to the headlight switch |
07-22-2011, 02:14 AM | #8 |
My CST/10 is a 1/2 ton 2wd and it has the factory cab lights with raised roof bases. I had never seen them in Alaska before I bought my truck.
You're not old, it IS loud! 1970 CST-10 BB 400 |
07-22-2011, 09:19 AM | #9 |
1 Tons must of had a different switch because there is no provision for the cab light harness on aftermarket headlight swtches.
07-23-2011, 08:38 AM | #10 |
It is rare to see clearance lamps ordered on 10 & 20 series trucks. I would think the ones you see would most likely be on a truck that was spec'd and ordered by a customer.
Just hook the lamps up to a toggle switch. That's what I've done when adding them. I always added at least the three center lamps to the rear,too. Then you can do the trucker "thanks" when someone gives you the courtesy flash.
07-24-2011, 09:19 PM | #11 |
The factory cab light harness does plug into the aftermarket headlight switch. It goes in the unused slot in the headlight switch harness. After not finding one by feeling around, I pulled the swtch and I saw the light.
