Old 04-05-2003, 03:49 PM   #1
Reumster
L.E.D. Freak
Reumster's Avatar
Question Early Classic Super Track bar problems? Pictures needed
I just finished tearing down my rear suspension and this bracket for the Super Trakc bar isn't bolting up. It's hitting on the trailing arm. The holes in the u-bolt won't line up. ???? Any ideas? Anyone have pictures of the stock kit bolted up?
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 04-05-2003, 03:55 PM   #2
Alexis
Member since 2000
Alexis's Avatar
stock kit or the ECE kit?
Alexis is offline   Reply With Quote
Old 04-05-2003, 07:03 PM   #3
Church
Carolina Classic Trucks
Church's Avatar
I may have some pic of the ECE super trac bar here:
http://photos.yahoo.com/bc/srcjeeper...c=ph%26.view=t
Mine went on with no problems.
Look at pic DSCN0458. It shows it bolted up at the passenger side trailing arm.
Church is offline   Reply With Quote
Old 04-06-2003, 04:02 PM   #4
Slammed67
Progress = 0%
Slammed67's Avatar
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 04-07-2003, 11:23 AM   #5
Reumster
L.E.D. Freak
Reumster's Avatar
Ok sorry been busy. The right side bracket finally went on. No problem. The bar really needs to be in the top hole. But it hits the frame in that hole. New exhaust going to be tricky.
(406)675-8082
Old 04-07-2003, 01:56 PM   #6
Slammed67
Progress = 0%
Slammed67's Avatar
Why does it NEED to be in the top hole?
Old 04-07-2003, 03:54 PM   #7
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I'm not sure either but that is where mine fit the best (angle) and I noticed an ECE set up in a mag and they used the top hole.
I'll use either hole personally
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 04-07-2003, 03:57 PM   #8
Alexis
Member since 2000
Alexis's Avatar
lol i think the bottom hole is for stock hieght to 4 inch drop. the top hole is for anything lowered more then 4 inches. I think that how it go's.
Old 04-07-2003, 06:50 PM   #9
Slammed67
Progress = 0%
Slammed67's Avatar
Yeah, I guess it could perform kind of $hitty if you put it in the hole that it wasn't designed to fit into
Old 04-09-2003, 02:18 PM   #10
LowSeventy
Reumster, why would your bracket not work? Mine was so simple my 6 year old could have done it. It fits between the trailing arm and axle saddle, just like in the picture in their instructions. The u-bolt drops down thru everything and holds it in place. Stan at ECE said to use the low hole on my 70 because I bought the 6" rear coils. How low did you drop your Blazer?
LowSeventy is offline   Reply With Quote
Old 04-10-2003, 09:42 PM   #11
Reumster
L.E.D. Freak
Reumster's Avatar
It's ok now. Fit fine. I was tired and a little tuned up at the time I guess! LOL
It's perfect I love the whole kit. I really think the shock relocator did alot of good on the handling. And I notice the difference in rear end movement from max ride height to aired out.
(406)675-8082
