07-22-2011, 11:58 PM | #1 |
Do I need drop spindles to get the front end on the ground?
I just got an 81 C10 and I am going to bag it all around.
I am running 28 inch tall tires, so do I need drop spindles to get the lower arms to lay? Should I pie cut the control arms to to keep the ball joints from binding and cut the lowers to make them drop arms? I plan on the ride hieght being as low as I can and still steer good, so I want the suspension to work good just a few inches off the ground. |
07-23-2011, 12:52 AM | #2 | |
Re: Do I need drop spindles to get the front end on the ground?
07-23-2011, 09:32 AM | #3 |
Cutting, welding and redesigning suspension parts is not something that should be undertaken by an amateur; or most professionals, come to think of it. It's tricky enough to remove and replace stock parts with well-engineered and thought out items and get the alignment back to specifications. With the amount of aftermarket stuff available these days, I can't imagine not being able to get your truck low enough with something pre-engineered for that purpose. Safety First!!
07-23-2011, 02:56 PM | #4 |
Thanks for the impute.
I guess getting drop spindles will keep me from trying so hard to get it low. I was just hoping that some hard work would save me some money for other things. I love to fabricate, But I will have plenty of that on the rear 4 link. I'm going to raise the whole bed up so that the wood floor can look nice. |
07-23-2011, 04:14 PM | #5 |
Happy to be here
Buying spindles is money well spent. You can only get so low anyway, unless you section the crossmember. Cutting the control arms is pointless because your not going to get that low unless you address the crossmember hitting the ground first.
07-24-2011, 11:19 AM | #6 |
You can do it without drop spindles but you will wear out your tires and your ride will suck... Drop spindles and really worth the extra cash.
White Lightning |
