Custom dash bezel
Have a 71 blazer and trying to install after market stewart warner gauges. I temporarily built a wooden bezel with cut outs behind it for the headlight and wiper bulges. Bought a Docs Custom aluminum billet bezel, but it doesn't fit just right. The mounting holes match, but the headlight and wiper holes don't and the cut outs behind wiper and headlight aren't shaped for the stock dash bulges. Any suggestions?
![]() Join Date: Feb 2000
Re: Custom dash bezel
I just used my stock bezel after cleaning it up and painting it.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Thanks Yukon Jack. I have already invested in gauges where the speedo and tack are smaller than stock (3 3/8). I found a dash panel at customdash.com. A little pricing but still cheaper than others and if fits nicely...maybe well worth it.
ran out of money
ive used a glove box door panel and welded studs on and put nuts from the backside. made it how i wanted my guages.
and yes i know the tach isnt level, i did this so i knew straight up was time to shift
Modify everything, leave nothing alone!~ ![]() ![]() |
ran out of money
ohh and if you do this the glove box door is 2 layers, you have to be careful and trim off the back panel so its only 1 layer thick. also need to weld up the button/lock hole
Back in the sticks
If you are going to use wood, you have to router out some wood to clear the dimples on the dash. Here's one of mine.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
oldschoolblazer@yahoo.com
see if this helps...
http://67-72chevytrucks.com/vboard/s...d.php?t=457264 |
