Old 07-25-2011, 11:42 AM   #1
specialtyretail
So,, what else you got???
specialtyretail's Avatar
hEATER BLOCK OFFS??
Looking to clean up the firewall and later on go with aftermarket heat/air cond. Where can I get the heater delete plates for now, not ready to do the whole install just yet. Just trying to smooth out the firewall right now. Thanks, Fred.
specialtyretail is offline   Reply With Quote
Old 07-25-2011, 12:04 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: hEATER BLOCK OFFS??
Porterbuilt Fabrication sells a weld in panel.
http://www.porterbuiltfabrication.co...ller-Panels-99
Keith
Convert to disc brakes.
Old 07-25-2011, 12:10 PM   #3
specialtyretail
Thanks Keith. Thought I saw some that were seperate pieces and even some that reshaped the upper area to match the drivers side. maybe i am imagining things, you know how everything runs together after awhile.
Old 07-25-2011, 02:26 PM   #4
gotchamel
Doing the same thing,today as a matter of fact.I removed all heater parts inside and out.I then made 3 cardboard templates for the 3 large holes.I cut some 1/8" aluminium plate to fit snugly and using Duraglass to fill void.I drilled a 1/4" hole in the centers of each plate and put in a self tapping lag bolt to make fit and check for fit easier.I don't weld but I am very good with glass work.I will get some pics up.I realize that weld in plates are best just did not have that option.
gotchamel is offline   Reply With Quote
