Old 07-25-2011, 07:10 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Difference b/t 67-72 Lowered Springs and 73-87 Lowered Springs?
Are there any difference? My 72 suburban has 73-87 Control arms, but has 6102-2 on the coil springs, which are 2 inch dropped. The number appears to be for 67-72. It's got me confused. I'm about to buy some drop spindles and want to get the correct ones.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 07-25-2011, 09:20 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Difference b/t 67-72 Lowered Springs and 73-87 Lowered Springs?
The springs are fully interchangeable.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-25-2011, 09:26 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
x2.
Keith
Convert to disc brakes.
Old 07-25-2011, 09:33 PM   #4
5150
C10 Club Tennessee
5150's Avatar
Thanks guys, I thought so, but alot of websites have different part numbers
Bryan
www.gmtruckshow.com
Old 07-25-2011, 09:35 PM   #5
Tx Firefighter
That I have never understood either. The spring vendors could sell more springs if they'd catalog them correctly as to heir fitment. 63-87 trucks and 63-91 Suburban springs all interchange.
Old 07-25-2011, 09:39 PM   #6
5150
C10 Club Tennessee
5150's Avatar
What's the difference on the spindles then? Mine are 1 inch thick.
Bryan
www.gmtruckshow.com
Old 07-25-2011, 09:42 PM   #7
Tx Firefighter
Lower balljoints fit 71-87, but uppers are 71-72 and 73-87 fitment. All 71-72 trucks used the 1.25 inch thick rotors. The early 73 and newer trucks also all used the same thick rotors. In the middle of the 73-87 range, GM started using the 1 inch rotors on some trucks but still continued with the 1.25 rotors on other trucks.
All that is from memory. If I'm wrong about any specifics, Keith will be along shortly to straighten it out.
Old 07-25-2011, 10:34 PM   #8
lolife99
lolife99's Avatar
Ha.
You have a perfect memory!
The 73-87 spindles are the only spindles that can be ordered to fit the 1" rotors.
If you need calipers and bearings,... as well as new rotors,... switch to the HD 1.25" wide version.
Keith
Old 04-09-2012, 04:28 PM   #9
mo1968
mo1968's Avatar
Are lowering coils from 1960- 1972 and the lowering coil form 1973- 1987 the same as well? I have a stock 72 front end. Websites have the 1960-1972 front lowering coils priced higher.
mo1968 is offline   Reply With Quote
Old 04-09-2012, 05:01 PM   #10
Tx Firefighter
63-87 all interchange but there are no 60-62 front coil springs. Those trucks used torsion springs rather than coils.
Old 07-25-2011, 09:53 PM   #11
5150
C10 Club Tennessee
5150's Avatar
Seems like there's less of a selection of spindles for the 1 inch rotors.
Bryan
www.gmtruckshow.com
