Rear disc headaches?
Well, slowly but surely making progress on the 57. Just got my No Limit Fatbar welded in, and naturally - the drive shaft is too long now! Anyway, next is new fuel lines (for new relocated tank) and brakes lines, as well as new rear brakes. Looking a disc conversion out back, and would welcome any shared experiences/lessons learned (particular brand, etc.), as well as difficulities with the parking brake cable on aftermarket rear disc conversions. I heard it can be a bear getting the parking brake together due to access (?). Thanks in advance, Jim
Re: Rear disc headaches?
I always use a Lokar cable kit when connecting up parking brakes.
Did No-limit make the 4-bar on your truck? Got any side shots to show where it connects to the frame? (please) |
Sure wildearp - thanks for the response!
Yes, I bought the Fat Bar set up from No Limit after much debate on whether to stay flipped leaf, go trailing arm or 4-link. It bolts (or welds) forward and welds elsewhere. You can go on their sight and download the entire installation sheet. I have heard that rear disc brakes offer a difficult application for the parking brake. I assume the cable mechanically applies pressure of caliper to disc as hydraulics do under normal operation - correct? That being said, has anyone experienced any difficulty getting it to hook up? Also, any feedback on product offered (CPP, SSBC, etc.)? Thanks much, Jim ![]() |
I already made a post in one of the forums with the difficulties I had with the CPP kit. I recommend the SSBC kits, Speedway Motors kits, or the kits sold by Currie Enterprises. Call Currie for availability, as their website was not up to date when I was shopping.
The kit I used has GM calipers with Ebrake. If you use a Lokar parking brake lever, go for the longer lever. The brake kits that use a drum brake shoe inside the hat of the disk brake (ford style) work better. My GM setup barely works if I give it a ton of effort. There is no way the wife can disengage the brake with the short Lokar lever. Here is the link to the other post: http://67-72chevytrucks.com/vboard/s...d.php?t=475483 |
mid 70s - 80s caddy had good disc rear ends that usually bolt right up . you may need to make some small mods but for the most part should work .biarritz is the name of that particular model of caddy - usually found in the junkyards these days .
that is if you want to change out the whole rear end -- good luck on your project! |
also i forgot - the caddy seville 70;s- 80s also is a good rear end disc setup
I went and pulled the whole rear disc setup off a 2000 Blazer 2wd. Fit perfect and has the parking brake under the rotor. Just connected the parking brake cable to the original location and now I can use my original setup.
Whole thing cost me less than $200.
Somehow, the idiots survive despite their best efforts to kill themselves. - dcozzi |
BIG CHEVY 3600 LONGBOX
I see you have a chevy 10 bolt. The eaisist disc conversion is a 2002 CAMARO TRANS AM 12" LS1 REAR DISC BRAKES. They will actually bolt on to your axles:http://s729.photobucket.com/albums/w...keCable-2.jpg&
My emergency brake is a foot stomper. From the crossover rod I used the Lokar setup: http://s729.photobucket.com/albums/w...=P5150122.jpg&
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 Last edited by BIG CHEVY 3600; 07-30-2011 at 12:44 AM. |
