Old 07-27-2011, 09:59 PM   #1
ubtripn
ubtripn's Avatar
my dumb mistake-Please help!!!
I had my power steering lines hanging down (zip-ties up out of the way) as I have been waiting for my power steering gear. Once every couple of days I strt the struck to keep its bloof flowing (Pump is empty without a belt on it). On of the ties must have come loose because it wrapped around the fan and bent it into a curl. The metal part. This is a 76 pump with SAE fittings and my PS gear on order is a 76. The one I bent is the one with the smaller end fitting.
Is this the return line? The parts stores sell one the you cut to fit and use hose clamps? Is this ok to do?
ubtripn is offline   Reply With Quote
Old 07-27-2011, 10:58 PM   #2
ubtripn
ubtripn's Avatar
Re: my dumb mistake-lease help!!!
ok, i looked closer and the metal tube is bent at a new place to about half capacity. I think it is the return, would it still work or should i just buy the universal one?
Old 07-27-2011, 11:54 PM   #3
70cst
70cst's Avatar
Re: my dumb mistake-Please help!!!
ttt
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-28-2011, 09:45 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by ubtripn View Post
..... Is this the return line? The parts stores sell one the you cut to fit and use hose clamps? Is this ok to do?
Usually the return line has clamps on it. Mine does. Comes off the side of the pump that has the metal tube. If it's all twisted up, I wouldn't use it. It may allow fluid through, but there could be stress cracks that could cause leaks or a major breakage.
You could try a salvage yard (take your old line) and try to match it up. They usually have a rack with p.s. hoses or old trucks you can take one from.
btw: What is "bloof?"
68gmsee is offline   Reply With Quote
