Advantage 52
What is the advantage of running 52" leaf springs on the front?
Re: Advantage 52
Re: Advantage 52
budget 4" lift, softer ride quality than standard lift spring, moves axle forward a bit, and keeps a more appropriate shackle angle.
there are some cons too, but you didn't ask abt that... |
Re: Advantage 52
Okay ...ncgamedog.. I will ask then what are the cons then.
Junk Yartist
Re: Advantage 52
K... I wanna know too. I have been going back and forth on 52s since I need to replace my front spring hangers. It will either be 52s or whatever length is on my 91.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
Re: Advantage 52
91.... are you sure you don't have 64's or 56's.
Re: Advantage 52
What are the cons?
What is the best way to level out the rear? |
#8 | |
Re: Advantage 52
Shackle flip for the rear! http://diy4x.com/cart/index.php?rout...product_id=112 http://offroaddesign.com/catalog/shacklekit.htm |
Re: Advantage 52
Thanks!
