07-29-2011, 08:19 PM | #1 |
Volt Meter not working
Hey guys,
Pretty new to this stuff, I just got a 71 Cheyenne SWB, noticed the meter isn't working. Is the any wires that connect to the meter or is it ran by the printed circut board. |
07-29-2011, 08:27 PM | #2 |
Junior Member
Re: Volt Meter not working
The stock meter is an ammeter and usually the two small fuses go bad. They are located on each side of the radiator.
Most people hook up a after market voltmeter.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
07-29-2011, 09:19 PM | #3 |
Its a Truck Thing......
Yeah,
look for the small black fuse holders, they have small glass fuses in them, always go bad. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
07-30-2011, 12:28 AM | #4 |
Eat, Sleep, Drive a Chevy
Welcome from Texas. What you see in the picture is correct there are no wires connected, yes it does use the printed circuit board. Check those fuses, even if they are good and all the other wiring is ok an amp meter wont move very much. If you have access to a DC volt meter check voltage across the battery terminals while the engine is running above idle speed you should see 14 volts. If you dont have access to a meter most auto shops and many parts stores will check for free
Good luck
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
07-30-2011, 10:43 AM | #5 |
Anyone know where to find the small fuses? I had to use standard length fuses and wrap electrical tape around them.
07-30-2011, 11:09 AM | #6 |
Thanks guys,
I looked for the fuses but no luck, there seems to be all new wiring in this truck. I have access to a to a volt meter and I will have to check that. Thanks again. |
07-30-2011, 11:30 AM | #7 |
Active Member
Another thing you can check after you make sure the alternator is putting out at least 13.5 (or slightly more) vdc is the ground straps.
If you don't know where they go do a search on ground or ground straps. |
07-31-2011, 12:54 AM | #8 |
I think they are SFE4 fuses, and I got them at a local auto parts store (most carry them).
The fuse holders don't look anything like any I have seen before. They are black and look more bulb-like, about 3/4" round and made of rubber. They are right where the fender meets the radiator support.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
