Old 04-06-2003, 06:06 PM   #1
mx jim
Question Can i use 3.08 insted of 3.73???
I have a 12 bolt rear end with 3.73 gears, out of a 1970 chevy short bed. I was woundering if i could use my rear end but put 3.08 gears in it? Or am i going to have to get a new rear end. Thanks jim. Bye the way i am 17 years old and this is my first truck.
mxjim 1970 chevy 4x4, 400 small block, 4" pro comp lift, with 35s.
mx jim is offline   Reply With Quote
Old 04-06-2003, 06:28 PM   #2
mikep
Used to have a truck
mikep's Avatar
You'd be better off finding someone who would trade their rear end for yours . Otherwise the gears and setup would put you around $500+ . I'm sure there are a lot of folks on this board who would be happy to do that if they live close to you.
No truck :-(
mikep is offline   Reply With Quote
Old 04-06-2003, 07:15 PM   #3
bpmcgee
bpmcgee's Avatar
I learned the hard way that when you swap from 3.73's down to 3.08s you need a different carrier.
Brian
bpmcgee is offline   Reply With Quote
Old 04-06-2003, 07:20 PM   #4
mx jim
What is carrier??
Old 04-06-2003, 08:04 PM   #5
crazy longhorn
Fabricate till you "puke"
the carrier is what the ring gear is bolted to(also houses the spider gears). The 3.08 is on a 3 series carrier, & the 3.73 & lower are on a 4 series carrier. I agree with MikeP, it would be much cheaper to swap complete rear diffs with someone, rather than set up gears & replace the carrier. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-06-2003, 11:59 PM   #6
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
bpmcgee, sounds like a destroyed ring and pinion set?? my pinion seal went out tosay on my way home from town. I guess its time to get the 3.08 posi ready and get new u-bolts and get a speedo gear too :-)
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 04-07-2003, 07:52 AM   #7
Ed ke6bnl
Re: Can i use 3.08 insted of 3.73???
presently we have two rear ends one is in the 70 chevy with a noisy 3.73 5 lug that we want to put 3.08'sin The other rearend is a 3.08 was told from a 70 ish pu with 6 lug and posi. can the center section from the 3.08 be moved to the 3.73. Thanks Ed ke6bnl So.Calif.
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 04-07-2003, 08:09 AM   #8
crazy longhorn
I would check the width flange to flange on the axles......if the spare diff is a 70, the 5 lug axles should swap in. The 67-69 diffs are 1 1/2" narrower. If you have the older diff, yes you can swap the 3.08 ring /pinion & carrier into your diff. You just need to check backlash before tearing the 3.08 diff down, & use the pinion shim with the 3.08 gears. After you are all set up , run the pattern with marking compound to be sure the pinion depth/backlash is correct. good luck,crazyL
