07-30-2011, 01:42 PM | #1 |
Trailing arm bushing replacement
how hard is this to do? mine are pretty rough. anyone done this before?
07-30-2011, 01:47 PM | #2 |
Re: Trailing arm bushing replacement
I'm wondering the same. It's the last thing I need to do to complete my suspension rebuild.
07-30-2011, 01:49 PM | #3 |
it's not bad,
I burned out my old ones and used ploy graphite new, |
07-30-2011, 01:51 PM | #4 |
i have to ask can you give steps to replacing them?
07-30-2011, 01:53 PM | #5 |
Project Junkie! Fishing Poor!!
If you want to burn the old ones out then you must remove the trailing arms first. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
07-30-2011, 01:56 PM | #6 |
i just want to replace the bushings they are pretty cracked and worn. this is a work truck i use mostly on weekends.
07-30-2011, 06:21 PM | #7 |
Get them pressed out. I like the not burning them out while installed post. I can picture someone with a torch down there catching their truck on fire and then blaming you stitch626.
07-30-2011, 06:35 PM | #8 |
motor exploder
Just unhook the arms from the front mounts, drop them down, drill a bunch of holes in the rubber around the bolt hole sleeve, knock out what's left with a big socket that's the same size as the bushing hole. Then pop in the new poly ones with a little lithium grease, or whatever is provided with the new bushings. No torch needed. If they are as rotted as mine were, they won't put up much of a fight.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
07-30-2011, 06:47 PM | #9 | |
even in the truck how you think shops did it.. anyway.. be safe. Last edited by stich626; 07-30-2011 at 06:53 PM. |
07-30-2011, 06:36 PM | #10 |
Wish I had a working scanner, could send you or post the manual pages on this. Pretty much jack up the truck, Block the front wheels, and back wheels to keep axle from moving. Place jack stands at rear on frame, not under axle.. Spray all the u-bolts on axle with PB Blaster after wire brushing. Spray the bolts at the trailing arm bushing and the drive shaft u joint bolts if you plan to remove this. I'd just put something under to hold up the front at the axle. Unclip the brake lines and parking brake cables from the trailing arms. Then remove axle u-bolts and bushing bolts at front of trailing arms.
That should be it. Put back in and retorque. Good luck. Jim |
07-30-2011, 07:01 PM | #11 |
Those look nice and clean stitch. I wasn't in any way saying that someone would do that in the truck, just laughing because someone had to say not to do it when installed. Thats all. Jim
07-30-2011, 07:59 PM | #12 | |
was it train or brain he say today I wonder where common sense went |
07-30-2011, 09:27 PM | #13 |
I used my balljoint press and pressed them right out
Fuzzy |
07-30-2011, 09:42 PM | #14 |
07-30-2011, 09:44 PM | #15 |
~Rest In Peace~
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
07-30-2011, 09:52 PM | #16 |
07-30-2011, 09:48 PM | #17 |
Hand Crafted C-10
There are also hand tools to get the job done.
This one is from Snap-on, driven by an impact wrench. |
07-30-2011, 10:00 PM | #18 |
Watch out for your cornhole !
Yes, the rubber replacements come with a vulcanized in place outer metal sleeve. The urethane bushings do not and require you to reuse the original outer shell, making installation much easier since you don't have to press the outer shell out.
11-23-2011, 10:30 AM | #19 |
Just a car guy
I tried burning mine out, was not very effective, so I switched to drilling.
I broke a couple small drill bits off in them. I did not remove the trailing arms from the rear axle. Do I was Domingo this with the arms under the truck. The bed is off so that made things easier. For installation, I was able to get the bushings about halfway in by hand, then had to use a c clamp to get them the rest if the way in. Posted via Mobile Device
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
11-23-2011, 10:52 AM | #20 |
Burn 'em!!!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
