Old 07-30-2011, 08:11 PM   #1
1moretoy
20x14 coys
CAN I run 20x14 coys on the back of my 70 c10 without narrowing the frame rails. the truck was a short step now it a short fleet. If I can what backspace would I need. thanks
1moretoy is offline   Reply With Quote
Old 07-30-2011, 10:53 PM   #2
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: 20x14 coys
I doubt it, but call them. They know C10's real well.
Zoomin is offline   Reply With Quote
Old 05-04-2012, 08:57 PM   #3
1moretoy
Re: 20x14 coys
Old thread but anyone know what I would need to make them fit. Thanks
Old 05-05-2012, 10:21 AM   #4
Hart_Rod
Hart_Rod's Avatar
Re: 20x14 coys
You'll have to narrow the rearend approximately 5" each side because Coys only offers them in a couple of back spacing options (5,4.5??). This wil probably necessitate some frame modifications, but I'm not sure exactly what. If you go with a wheel that offers more back spacing options, you could do it with out narrowing the rear. I have 20x12's (7" bs) on the back of my truck and the only modifications are widened tub and removed the bump stop bracket.
Hart_Rod is offline   Reply With Quote
Old 05-05-2012, 10:50 AM   #5
BossHogg69
motor exploder
BossHogg69's Avatar
Re: 20x14 coys
I'm running 18x12's with 7" bs also - there is plenty of clearance between the inside of my wheels and the frame rails, easily 3+ inches. You could always get the Coys and have them widened toward the inside like I did with my Boss 338's. I will say that careful use of a measuring tape will be your best friend in trying to find out what will work on your particular truck.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-05-2012, 11:19 AM   #6
okyankee
Re: 20x14 coys
what size tires are you running on the back?
okyankee is offline   Reply With Quote
Old 05-05-2012, 12:33 PM   #7
Hart_Rod
Hart_Rod's Avatar
Re: 20x14 coys
Who widened them for you?
31 x 16 Mickey Thompso Sportsman Radial.
