Old 08-01-2011, 11:42 PM   #1
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Brake Booster M/C choice
Ok guys its getting time to choose which booster and m/c to go with for my truck. I have the original 11 in booster set up but would like to see what you guys think. So here is what I can tell you about the truck.
1) The motor will be pretty well stock so I am not worried about any vacuum issues. I have seen lots of the smaller 8" dual boosters but dont really know how they perform as compared to the factory booster
2) I am shaving the firewall and dont want too much there. But what will be there needs to look good too
3) I am going to run the Captain Fab rear camaro disc in the rear
ok...let the opinions fly
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 08-02-2011, 05:54 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Brake Booster M/C choice
I had a stainless steel dual diaphram booster on my Chevelle and it was great. I also used the CPP master cylinder (MCPV-1) with double adjustable proportioning valve, removable metering valve and stop light control all in one.... not cheap but nice setup.
If you want a clean bracket, just get the captains booster bracket... but it doesnt work with the factory column shift.... not sure what you're using....
Rich
1972 K5 Blazer CST Click HERE
Old 08-02-2011, 08:38 AM   #3
chevytruckluver
That is good information to know, I do have a factory tilt column I am wanting to use at this time. Is it an issue with the column or the solid shift linkage? I have seen trucks with the cable shift attached to the column before.
Trey
72 Short Step
Old 08-02-2011, 10:52 PM   #4
AusTx68
AusTx68's Avatar
I also went with the MCPV-1 and I'm running the captain's camaro rear disc brakes. The CPP master cylinder cleans things up by eliminating the need for a prop valve. Looks real nice too. When I made the swap I stripped and painted my brake booster to match the exterior paint. The end result is a show worthy appearance. If you are trying to stay stock the MCPV-1 is probably too much bling.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 08-02-2011, 11:01 PM   #5
chevytruckluver
Nope not trying to stay stock, just looking for something nice...can you post up a pic of yours?
Trey
72 Short Step
Old 08-02-2011, 11:24 PM   #6
AusTx68
AusTx68's Avatar
This was the best photo I could get given the current lighting:
Old 08-03-2011, 09:20 AM   #7
chevytruckluver
I would have to agree...show worthy!
Trey
72 Short Step
Old 08-02-2011, 08:56 AM   #8
mcmlxix
mcmlxix's Avatar
Check out his thread... I cant remember what the interference was.. The Lokar cable shift for the column may solve the problem... I dont think anyone posted pictures...
Rich
Old 08-02-2011, 10:18 PM   #9
chevytruckluver
am I missing something?...what thread?
Trey
72 Short Step
Old 08-03-2011, 03:25 AM   #10
mcmlxix
mcmlxix's Avatar
HERE
Here is the setup I had on the Chevelle...
Rich
Old 08-03-2011, 09:24 AM   #11
chevytruckluver
HERE
Thanks Rich
I know that bracket would add some room inside the engine bay which could be a good thing also
Trey
72 Short Step
Old 08-02-2011, 11:03 PM   #12
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
powdercoated or aluminum MC i hate a rusty MC (mine is)
John
1999 Toyota Tacoma 4x4
Old 08-03-2011, 04:48 AM   #13
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i went with the cpp mc booster with pv
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-03-2011, 09:22 AM   #14
chevytruckluver
This is very simular to the factory set up I have now. I like the gold iridated finish also
Trey
72 Short Step
Old 08-03-2011, 10:13 PM   #15
chevytruckluver
any other thoughts or ideas?
Trey
72 Short Step
