Old 08-04-2011, 03:02 AM   #1
kanuck
700R4 housings? Different in 4x4 and 2wd??
Was wondering if you can add a tail housing to a 4x4 tranny to be able to use it in a 2wd truck?
Also, what is the difference in electronic speedo and cable? Do you just ad an adaptor?
Thanks for any info....
Hagen
'70 Malibu with 383 stroker/T350
'56 SWB Mercury pickup..under construction
'67 Firebird Convertible...all done stock
'70 LWB 350 on propane...beater
'69 LWB 350/T400 body restored
kanuck is offline   Reply With Quote
Old 08-04-2011, 06:43 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 700R4 housings? Different in 4x4 and 2wd??
these are the different sizes
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-04-2011, 08:08 AM   #3
BigBlocksRule
Tailhousings are different as are output shafts. Both can be swapped without tearing the entire tranny down. Two different configurations for speedo, one uses a plastic gear (mechanical) and the electronic version uses a magnetic reluctor wheel. Both go on the same place on the output shaft. Ask your tranny guy for sure about this when you swap the output shaft and tailhousing.
Also, make sure you're running one of the later 700's ('89 and up, IIRC). Easy way to identify the case is that the case casting line runs right through one (or both?) bosses for coolant lines, the earlier ones miss it completely.
BigBlocksRule is offline   Reply With Quote
