08-05-2011, 10:53 AM | #1 |
Heat causes starter to freeze
My grand dad just gave me his 72 sportvan, which he purchased new. He told me at times when its hot out, and the engine is hot (not overheated) the starter will freeze up due to the heat from the exhaust pipe which runs down next to the starter. It has a 350 engine. My question is does anyone know what I could use to insulate the starter from the exhaust pipe to keep the starter from over heating. He said in the winter it does not happen. My new van is in pristine condition and I love it.....Josh
08-05-2011, 11:20 AM | #2 |
Re: Heat causes starter to freeze
I bought one out of the LMC catalog and it cured the problem for me. You can make one easily. Here's the link to the homemade one below:
http://67-72chevytrucks.com/vboard/s...d.php?t=465300
. . . . Life is short . . . we only have, right now. . . . . My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526 |
08-05-2011, 11:21 AM | #3 |
They sale starter covers from jegs for around 25 dollars. I bought one for my rock crawlers.
Master welder I've got a degree in metalfusionology
08-05-2011, 09:33 PM | #4 |
You could probably make your own. Sheetmetal + snips. Maybe even use an empty can of peas or corn.
project: "my happy mess" |
08-05-2011, 10:38 PM | #5 |
~Rest In Peace~
disposable turkey pan
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
08-07-2011, 02:15 AM | #6 |
nice call. dissipate heat quicker your way. pea or corn can for exhaust patch.
08-07-2011, 02:43 AM | #7 |
They make an insulated starter wrap/blanket too.
I had the same problem on my 70 Camaro. Once in awhile I'd forget and turn the engine off. I'd have to wait 45-Hour for that S.O.B. to "Cool Down", before I could start it and take off!
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
08-05-2011, 09:53 PM | #8 |
Welcome to the site! Wrap the header pipe next to the starter with header wrap. A high torque mini starter would also help.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
08-06-2011, 07:22 AM | #9 |
Yeah my truck does that too. Post pics of the van!
Posted via Mobile Device |
08-07-2011, 06:13 AM | #10 |
I was having heat soaked starter solenoid problems, I bought a remote solenoid from summit and it fixed my starting issues.
08-07-2011, 11:39 AM | #11 |
09-24-2011, 06:33 PM | #12 | |
I couldn't find the kit on your website. I wil PM you. Matt
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
08-07-2011, 02:29 PM | #13 |
Between Trucks...
This worked for me as well.
Beat it to fit, Paint it to match... |
09-25-2011, 08:38 AM | #14 |
This is a sign of an aged starter that will end up failing you. You don't have this problem with a healthy starter/solenoid. I just replace the starter with an OEM type and have never used a heat shield or any fancy starter. Works for me. A heat shield helps prevent heat from killing your starter prematurely due to headers being so close. But again,I've never had a starter fail so often that I've felt the need to add a shield. I run headers on everything.
09-25-2011, 10:27 AM | #15 | |
09-25-2011, 02:16 PM | #16 |
Msgt USAF Ret
Here's a couple of wiring diagrams for the remote solenoid.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
09-25-2011, 09:06 PM | #17 | |
Junior Member
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
09-25-2011, 06:11 PM | #18 |
Awesome. Thanks VetteVet.
09-25-2011, 09:33 PM | #19 |
Knocked this out this evening. Thanks to all who helped. I am still thinking about replacing the starter but will probably wait to see how this has helped. It was pretty easy and went well. I ran the wires away from all heat sources. Cost about 30 bucks for the solenoid, some 10 gauge wire and a new battery cable.
