Old 08-07-2011, 09:27 PM   #1
Rogue_Alphonse
Rogue_Alphonse's Avatar
I modified my dash pad.
I'd post a before pic, but I think everyone here knows what an original blue dash pad with cracks looks like. Basically I peeled off all the vinyl from the foam, then applied expanding foam in the middle part and shaved it down. Then I glued on the insulation that is used underneath pergo or "floating" flooring, and finally attatched the khaki material to that, in two layers. The pic of the pad totally covered before it's in the truck is just one layer. I used LocTite spray adhesive [honestly because I didn't think I had enough 3M Super-77 which is also a great adhesive]
Why khaki? I am later on going to cover my headliner and a couple door panel pieces with it as well. I like to be different in odd ways.
The pics follow:
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 08-07-2011, 10:08 PM   #2
OnDaTrail
OnDaTrail's Avatar
Re: I modified my dash pad.
Khaki should look good with that light blue paint . I'm pumped to see how the door panels come out
1983 GMC Sierra K2500- The Rat
1986 Chevrolet Silverado C10- The Donor
The DD: 1999 Chevy S10- 4.3 Vortec, 5 speed, Ext Cab
OnDaTrail is offline   Reply With Quote
Old 08-07-2011, 10:13 PM   #3
Rogue_Alphonse
I'm debating on making the interior grey and tan with a silver metal dash or leaving it blue with tan though, because the '98 Sub seat is grey already. I for sure am painting all the plastic and metal upper trimmings tan to match the khaki headliner and dash. My original plan was tan door panels, khaki inserts around the handles, grey carpet on the bottom and floor, and whatever is metal would be silver because eventually I want the truck that color.
I always look through pics of other square's for ideas though, so it's always changing!
Old 08-07-2011, 10:23 PM   #4
SS Delux
SS Delux's Avatar
Great job on the dash, might have to do that to mine. What seat do you have ?
SS Delux is offline   Reply With Quote
Old 08-07-2011, 10:26 PM   #5
Rogue_Alphonse
Thanks! The seat is out of a '98 Sub. It's actually power but since my dad actually put it in, it's attatched to the original bench adjusting track.
Old 08-08-2011, 03:50 AM   #6
cr34t3d_by_d4rkd3n
looks cool!!!
cr34t3d_by_d4rkd3n is offline   Reply With Quote
Old 08-08-2011, 10:51 AM   #7
jimboh247
jimboh247's Avatar
Definitely an improvement over a crappy cracked dash. How hard was it to get the original vinyl off?
'85 SWB Silverado
jimboh247 is offline   Reply With Quote
Old 08-08-2011, 10:59 AM   #8
Rogue_Alphonse
really it wasn't too bad considering I had a lot of starting points. I just used a regular Husky scraper to help peel it off in big chunks.
Old 08-08-2011, 12:05 PM   #9
Doug_J
Doug_J's Avatar
Looks really go almost think that would be better then filling in the cracks other then being alot more work...
Doug_J is offline   Reply With Quote
Old 08-08-2011, 12:26 PM   #10
Rogue_Alphonse
Well worth it, though I wish I had used thicker material.
Old 08-08-2011, 06:29 PM   #11
OnDaTrail
OnDaTrail's Avatar
Thicker material as in the khaki or the insulation?
Old 08-08-2011, 07:25 PM   #12
wyattglock
wyattglock's Avatar
Looks good! How thick was the khaki material?
wyattglock is offline   Reply With Quote
Old 08-08-2011, 07:57 PM   #13
Rogue_Alphonse
Thicker khaki. It was about as thin as a piece of construction paper.
