\/ My Loves \/
Lowering Springs (Front only)
I wanna lower my front 2 inches in a few weeks. How much do 2 inch lowering springs cost, are they hard to install, and where can i aquire some? Thx guys for all your help.
Tyler ![]()
78' Silverado - Blue - (In a Coma) 04' Silverado -Red- 383 Stroker in progress for the 78'!!! |
Gearhead since birth
It is a very easy job can be do in about a hour it depends on how hard it is to get your ball joints to break loose. While you have it apart check you b-joints and make sure they are still tight if they are not then go ahead and replace them while you have it apart . Have you ever taken spring out before? If not you want to get a coilspring compressor becouse there is alot of preasure on the spring and they can take your head off if you are not carefull Auto- Zone has the compreesor the loan them you pay a deposet and when you bring the tool back you get your money back, You can find the springs In any mag. There are tons of company's selling them Hope this helps later B.
Bam !!!
Here are a few for ya.....
http://www.performancesuspension.com/main.htm and http://www.sporttruckdirect.com/C10_kits.html |
Be sure to get a high quality progressive rate spring with a lifetime warranty or you will be very disapointed with the ride and handling. If you can afford it go with drop spindles instead and you can use your exsisting shocks with no gecmetry change to contend with.
Rest in Peace Ed. Thanks for all the good times. |
i've had both and much prefer the spindles over the dropped springs
Under construction!
Spindles maintain the factory ride quality and coil springs will make the truck handle better---This largely depends on what kind of springs you purchase.
Coil springs from DJM and Western Chassis will give a smooth and compliant ride. Belltech and Eibach are performance oriented springs---The ladder being my choice because they're a variable rate design and still ride well. ![]()
2001 Silverado bagged on 22's. *Sold* |
Low & Slow
Don't forget about early classic's springs. I've got their 2/4 drop springs and I love them.
70' C-10 LWB Fleetside 4.5/6 drop ![]() |
67-72 Addict!
Hotrod, did you get the shorter shocks and shock relocators also?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
I lowered mine with 1.5" springs and had to go with spindles as well, 2.5" for a total of 4" It was all done in my garage with ordinary tools, and I'm a novice. Everything came from Western and I opted for DT Dropped shocks. Western was good about getting me the right shock for the application. The previous coils had been cut and the ride was horrible! Now it is much lower and rides better. 76' Chevy S/S 454. Consider your motor when lowering, mine is obviously heavy.
