Old 08-13-2011, 12:17 AM   #1
ubtripn
ubtripn's Avatar
Possibly Good Mod
I was installing new headgaskets on my Outback and about everything else. I noticed the windshield washer resevoir has little pumps mounted right on it. One for the back and one for the front. I am going to pull one from a junkyard, use only one of the pumps and keep the other as a spare. (They are about the size of a matchbox car.) Then wire it into my wiper switch and mount the resevoir in my engine compartment. The icing on the cake is that the resevoir takes on full bottle of fluid. Not 8/10's leaving you with a bottle to store and then top off the truck with later. (Not sure why they all don't do that.)
ubtripn is offline   Reply With Quote
Old 08-13-2011, 07:42 AM   #2
cdowns
cdowns's Avatar
Re: Possibly Good Mod
anumber of guys have done similar swaps over the years
taking a full bottle is good only the first time i fill it// i always fill on a regular basis i dont run it out of fluid, same thing with the gastank
Old 08-13-2011, 01:24 PM   #3
ubtripn
ubtripn's Avatar
I thought that might be the case, I had never run into the mini-pump or the resevoir that takes a whole jug of fluid until I got this Outback. Thanks.
Old 08-13-2011, 02:37 PM   #4
truckster
truckster's Avatar
The electric washer pump was one of my first mods on my Blazer. There are all kinds of tanks/pumps you can use. I know a popular one is the S-10 bottle and pump.
truckster is offline   Reply With Quote
Old 08-20-2011, 10:52 AM   #5
wilbilt
wilbilt's Avatar
My wife has a Mistubishi Lancer with a reservoir that holds gallons of fluid. It looks small from the top, but the main part sits underneath the front fender/bumper. The first time I filled it for her, I just kept pouring...and ...pouring... I had to look underneath the car to make sure it wasn't leaking out the bottom!
1971 GMC C2500 Custom Camper - Second Owner.
350/TH350, Dana 60 Rear.
wilbilt is offline   Reply With Quote
Old 08-13-2011, 11:52 PM   #6
ubtripn
ubtripn's Avatar
Thanks, I will have to look at it.
Old 08-14-2011, 10:41 AM   #7
68gmsee
Active Member
68gmsee's Avatar
It was one of the first things I did on my 69, also. There used to be a pump kit one could buy at the auto parts stores and it ran well for many years until the motor burned up. I rebuilt the original one after that and used it until I parked the truck a few years ago.
68gmsee is offline   Reply With Quote
Old 08-20-2011, 09:04 AM   #8
ubtripn
ubtripn's Avatar
Great info - thx!
