Old 04-08-2003, 02:51 AM   #1
chevypete396
chevypete396's Avatar
Want to lift the 68... (Need planning help)
I still have space issues but I think I've decide to keep my 68 and get rid of some other stuff instead. Now that its not my primary vehicle anymore I want to get it lifted. Since it dosn't have to be on the road as my daily driver I can finally do some serious work to it and get this project back on track... Anyway.
I am leaning towards a 6 inch suspension lift with 35x12's so I can make better use of the 4.56 gears. I think of all the pic's I've seen I like that stance the best.
So hears my main question. Do either of the axles need to be turned to safely accommodate a 6 inch suspension lift? The transfer case lowered?
I know from past threads The rear springs have to be custom made. I think I have found a decent shop to make the springs and u-bolts for the rear axle. I am trying to steer clear of blocks or shackle flips.
I am also trying to get a softer riding ¾ ton truck through this (shouldn’t be that tough, the truck rides like a tank so it couldn’t get much worse) I guess soft ride front springs can be purchased through SkyJacker, are these smother riding springs or hype? I am not worried about sacrificing payloads but will they be ok to support a big block with out adversely affecting ride height.
I also read that a little steering work is needed like a special pitman arm? Who makes good ones? The truck in question is the 68 in the sig. It has power steering if that makes a difference. Is a pitman arm all that will be needed to safely correct the steering.
I want to do most of this myself but this will be my first attempt at lifting a truck so I am sure I will have a lot of questions. Thanks for any advise or help with this... Pete.
P.S. does anyone remember the link to the axle ratio -to- tire size -for- highway speed calculator? I still need to do some home work to see if 35’s will be big enough for those gears.
1968 Chevy - 3/4 Ton - 4X4 - Longbed - 383ci - TH350 - NP205
Building the motor, painting the engine bay, rewireing everything...
(775)-527-1199 / ryanspeterson@msn.com
chevypete396 is offline   Reply With Quote
Old 04-08-2003, 05:20 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Do you have the original front axle? From your signature, maybe the front has been swapped also and if it has all you need is a new steering arm, but if you have the 68 front w/ closed knuckles that's a different steering arm. I still have my drums up front and w/ the 33s I've noticed a decrease is stopping so if you have the front 68 you might want to goto a newer (71+, 73+prefered) axle and kill 3 birds w/ one stone(bigger u-joints, disc, steering arm).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-08-2003, 08:47 AM   #3
chevypete396
Yea I got a 14 bolt in the rear but up front I still got the original 68 closed knuckle setup.
I want to replace the front end before the lift. I plan on scouting the junkyards this week but I am not exactly sure what to look for though?
Which 3/4 ton GM front ends newer than 73 will work? Are any available with a more common lug pattern? I really want to ditch the closed knuckle I know that much but I also want something I can use my 4.56 gear set in and get a more common lug configuration at the same time if its possible. I am not sure the lug configurations available on ¾ tons through newer years let alone which newer year front ends will work with my gear set and springs… I guess I'm looking to kill 6 birds with one stone. Is that possible?... Thanks for the help so far... Pete.
Old 04-08-2003, 01:22 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I believe the dana 44 was available until 1977 and later in GMCs all 3/4 tons will be the 8 on 6" pattern. From the catalogs and sites I've visited your gears should work in any of those dana44s. Heck, you might even be able to find a 3/4 ton dana44 w/ 4.56 gears. All the chevy fronts are interchangeable from one to the other. Do you have power brakes? I understand that with disc up front that's more desirable. You could also swap in a 3/4 ton GM 10 bolt axle but you will not be able to use your gears.
Old 04-08-2003, 03:45 PM   #5
1969 GMC
1969 GMC's Avatar
I know in 71-72 they started to use front discs in 2wd Chevies/GMCs, did they also start to use disc braked open knuckle dana 44's? If so, that'd be a straightforward and easy swap.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-08-2003, 09:04 PM   #6
chevypete396
Thanks, yea sounds like I will try to go for a open knuckle disc front 44. I have power breaks but I think you have to swap master cylinders and proportional valves if you switch to discs up front so I will try to score those off the donor vehicle as well... Pete.
Old 04-09-2003, 05:40 AM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
As far as open knuckle axles availability, it seems some late 69s had them and all 70s w/ drums, in 1971 they were all discs.
Old 04-11-2003, 07:08 PM   #8
jerry moss
Born Psycho
jerry moss's Avatar
4.56 dana 44 with discs
i know where one is sitting near merced, ca. under a 73 chevy 3/4 ton 4x4. i'm sure it could be had pretty reasonable. not sure of the condition or anything else about it. my nephew lives near there and i ran the numbers off the housings for him--he was looking for a 3.73 set up for his 76 suburban 4x4. i can have him check on it for you if you're interested in a little road trip.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 04-11-2003, 07:24 PM   #9
chevypete396
hmmm, How close is Merced to Navado Ca. (or Santa Rosa)?
Also, I am still trying to figure out if the axles need to be turned for a 6 inch suspension lift? If the transfer case needs to be lowered? Anyone?
Thanks… Pete.
Old 04-11-2003, 07:40 PM   #10
jerry moss
Born Psycho
jerry moss's Avatar
Pete,
merced is in the central valley south of santa rosa by a bunch. you would be better off to catch hwy 99 in sacramento and head south from there-- 2-3 hours depending on how fast you drive.
i run a 6 inch skyjacker on one of my 3/4 ton 4x4s with no driveshaft probs other than lengthening them. my only real problem was getting the steering geometry correct, i ended up using a rancho 4 inch arm and a superlift 2 inch draglink to get the steering box centered. i didn't have to lower the t-case or rotate the axles.
jerry moss
Old 04-11-2003, 08:33 PM   #11
chevypete396
Jerry that’s a little far for me at the moment... I am going to look around town a little more but thanks a bunch.
Thanks for the other help too. Are you happy with that 6 inch Skyjacker lift?... Pete.
Old 04-11-2003, 11:15 PM   #12
jerry moss
Born Psycho
jerry moss's Avatar
Pete,
it rides a little stiff but not too bad. it is the softride version, also.
jerry moss
Old 04-12-2003, 12:23 AM   #13
chevypete396
Stiffer than stock? I sure hope not that would be a little disapointing. I been in newer lifted 3/4 ton trucks (76 w/ 6inches) that rode much better than mine stock...
Thanks... Pete.
Old 04-12-2003, 09:48 AM   #14
jerry moss
Born Psycho
jerry moss's Avatar
mine rides stiffer than stock
jerry moss
