08-14-2011, 02:56 PM | #1 |
Heater delete, but not AC?
Prob one of the strangest ideas that has been on here in a while! In the process of rebuilding the whole AC system on the 72 with factory air (and no I do not want to go to a Vintage Air system on this truck) and got the idea of deleting the HEATER but not the AC. In South Texas it doesn't get cold enough to warrant a heater in my project (not a daily driver, for sure not in winter) but I want the AC. Can I take the heater core out and fiberglass the holes in the box and after repainting it no one will be the wiser? Would I get more air flow for the AC or not? And is there parts of the stock box that I could take out then to save a little weight and make simpler? Thanks for considering and commenting
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
08-14-2011, 04:01 PM | #2 |
Old Skool Club
Re: Heater delete, but not AC?
I don't know why you can't. After all, it's two holes on the outside, right? If they're gone there's no where for the core extensions to protrude.
You may have issues if you have to defrost/defog your windshield, but I don't know that for fact.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
08-14-2011, 06:05 PM | #3 |
No reason that shouldn't work. Also, since the heater is sitting inside the cab and is full of hot water (unless you are running on "inside air") you should be cooler in the summer if you take it out.
1971 C10 Longbed, 350/TH350 |
08-14-2011, 08:01 PM | #4 | |
You will have better luck rebuilding the A/C case to stock specs...Than re-inventing/re-engineering it. |
08-14-2011, 10:17 PM | #5 |
Its a Truck Thing......
I rebuilt the whole inside of my truck to stock but, upgraded the outside to newer parts along with a sanden compressor, works really well, 38 degrees at night and 40 during the day. Also put on a pusher fan to keep the condersor cooler....
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
