Frame Chopping.... Opps I cut off too Much !
Yepper the Subject say's it all. For some reason the 8"off the back was too much. The rear cross sill has no place to sit (or bolt to) Kinda a warning message.
Watch out. ![]() ![]() ![]() ![]()
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Recovering Truck Driver
At least it was the back of the frame.......better than the middle....hehe
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
Fabricate till you "puke"
How much too short is it Mario?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
I at least 3" I will know when I get the box bolted together and set it on the frame Kinda a Bummer My frame looks so nice. At leastr it's not powder coated I could not even touch it up with out alot of time and money.
Later
Cantankerous Geezer
Fire up the welder an get out the grinder. Mario has an oops to fix. But you weren't supposed to tell us, now you have to let us humiliate you. Like we've never done anything that stupid!
Fred There is no such thing as too much cam...just not enough engine. ![]() |
![]() Join Date: Aug 2001
So just forget about the bumper and install a roll pan!
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
ready for reassembly
dude, that sucks!!
I've seen Mario's frame....it does looks really nice. It's a shame you're gonna have to hack it up again ![]() do you still have the part that you cut off?? get out your welder, buddy! haha Jason ![]()
stock 71 4x4 2003 Jeep Liberty, rocky mountain edition I'm obsessed, and wouldn't have it any other way! |
I think Mario cut what we told him to......damn that bites. Oh well, the welder will fix it
Something doesn't sound right. I know of three other "cut down" LWB frames and all have had 8 inches cut off the rear of the frame and everything fit great, beds and bumpers. Hmmm...............
i love summertime
yeah it says 8 inches in that article, but ive been told 6 by guys that have done it, i think gene was one of them, im going to cut 6 and go from there, under the cab was no sweat though
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
![]() Join Date: Jun 2002
I took 8" off the back of my frame too, and it worked perfect. The (new) bumper bolt holes are already drilled in the frame. Put the rear bumper on last weekend and it tucks in to the bed great., about 1/4" gap b/t bumper and bed. I would do some more measuring before any more modifying of frame. Good luck
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
You can always scap a new piece from a donner frame back onto it now that you have learned your lesson...........
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
I will see later this week when I get the box together what happens.
#14 | |
#15 |
huh ???
That Sounds like my luck, cut something 3 times and it's still too short... lol
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
#16 |
My cousin wants to shorten his 69 longbed, and we laid underneath my 70 and measured my short frame and his long. You need to do just what they did in the article in CCT. 12" out of the center and 8" off the very back of the frame is the difference between our trucks. Hope that helps.
#17 | |
I am wondering why some trucks need 6 and some need 8? Last edited by Gene; 04-09-2003 at 04:19 PM. |
#18 |
i dont know if it has anything to do with it, but my blazer and dads burb both have a rounded part on the back of the frame where the bumper bolts up to and my truck is flat on the back and has brackets that the bumper mounts to... i'm not sure if any trucks are done like the blazer/burb but taht could account for a few inches...
-just my thoughts...i dunno
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires -'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree -'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials -dads '70 burb (red, 5-7 drop, 350...) www.geocities.com/userc10/truckhome.html AIM: Auntjoedadda |
#19 |
Thanks For the repelys.
Gene, I think if I weld 2 " more on the back that will be enough. I saved the old piece for some reason........ and I have no Idea why. I will put the box on and see how much I actually need and go from there. I guess I should get the bumper and brackets soon or before I start to weld or cut anything else off. My truck is also a leaf sprung truck soo mabye that had somthing to make the measurements diffirent that the others. I am not mad at the fact that I cut too much off. I just did what was described I also checked with some other sources, checked again then started cutting. No worrys. Later Dudes.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 04-09-2003 at 05:02 PM. |
#20 | |
That's right, I'm back in the game again. No it's not pink..... 1972 Blue and White Suburban. |
#21 | |
![]() 72mario I dunno, my truck is a coil sprung truck? |
