Old 08-15-2011, 08:21 PM   #1
Rogue_Alphonse
Rogue_Alphonse's Avatar
A/C condensation leaks under the dash
in the same spot my heater core leaked the beginning of the year.
So obviously I looped the coolant line for the time being, and am going to replace the heater core soon.
I took off the cover under the dash to figure out why my fan was whistling, ended up a metal door had opened too far and the vacuum thing that controls it had broken off. Fixed that.
After about 2 months of working A/C, it started dripping in the cab.
Before I get into this heater core replacement, which will involve figuring out why the A/C condensation leaks in the cab as well, anyone have any ideas that could be the issue?
It's the type that you have to remove the inner passenger wheel well to get to the bolts to remove all that bulljive under the dash JUST to get to the heater core. Is there a condensation line I don't know of?
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 08-15-2011, 09:18 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: A/C condensation leaks under the dash
should be a hole under the housing in the engine area
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-15-2011, 10:01 PM   #3
Rogue_Alphonse
Could it be clogged though? as in could a damn mouse get in there? I know I found one in my windshield washer fluid reservoir...
Old 08-15-2011, 10:21 PM   #4
78 Chevyrado
Check on the AC box mounted to the outside of the firewall, for the hole it's like a 1/4" hole, its near the seam where the two halves come together around the eveporator and back near the firewall. If it's clogged up you will get drips in the cab. Use a mirror and a flashlight and its pretty easy to see, unless its covered up with something.
78 Chevyrado is offline   Reply With Quote
Old 08-15-2011, 10:27 PM   #5
Rogue_Alphonse
I'll take a look at it tomorrow, thanks a bunch!
Old 08-15-2011, 10:47 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
lol think i've seen pics of Camel spiders in there.....mouses will fit
might feel the bump down to the lowest point
John
