Old 08-16-2011, 08:07 AM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Differential trouble?
O.K. Since my '70 stepper is now my DD, I've noticed something odd. Truck has a OEM 3.07 posi rear. When making a left turn from a stop, it feels like the rear is "grabbing" /(slipping?). There is some audible but light noise. Once you straighten out, it's fine. And, it doesn't seem to be as noticeable on a right turn from start. I had the local lube guy check the oil and it's full.
I'm thinking I should pull the cover and check for wear, and hopefully refill and go.
I want to add a fill plug. What level???
TobyArnot is offline   Reply With Quote
Old 08-16-2011, 09:01 AM   #2
cdowns
cdowns's Avatar
Re: Differential trouble?
12bolt rears came from the GMfactory with a fill plug// they did not however come with a drain plug
it is good to drain and check for wear// i like using synthetic when i do the job, most synthetics you dont need a posi additive like dino stuff needs
Old 08-16-2011, 10:03 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
This is common with posi rears and all you would need is a bottle of posi lube.
I'd add a bottle of posi additive and do some figure 8's to work it in. Should fix it.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-20-2011, 09:17 AM   #4
TobyArnot
TobyArnot's Avatar
Thank all!
Drained the rear, looked good, no metal inside. Filled with fresh gear oil plus a bottle of GM posi additive, did the figure-8 thing and all appears to be well. Even took time to strip and paint the cover.
Old 08-20-2011, 10:12 AM   #5
bobs409
bobs409's Avatar
I love a happy ending.
Glad things worked out for you.
Bob
