Old 08-18-2011, 05:34 PM   #1
Btc10
Alternator light problem
I have a 1970 c10 truck. My problem is that when you turn the key onto the on position is it suppose to light up. But, it doesn't. It wont light up at all. Can somebody help me with this?
Btc10 is offline   Reply With Quote
Old 08-18-2011, 07:23 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Alternator light problem
Have you checked to see if the bulb is burned out? Might be all you need.
If that's not it, you may want to check the ground on the engine to cab behind the drivers side head. If it's not there install one. If it's there, make sure the connections are clean. Also check the negative battery to engine cable to make sure it has a clean connection.
I had an amp gauge that didn't work until I installed several ground straps for another electrical problem.
68gmsee is offline   Reply With Quote
Old 08-18-2011, 09:01 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if your truck has the amp guage, then the alt light isn't supposed to light up at all.
Old 08-18-2011, 11:28 PM   #4
Btc10
I don't have an amp gauge. I got the alternator light to work now. I moved some bulbs around on the back instrument panel and it started working. Thank yall for the information. I appreciate it.
