Old 08-20-2011, 12:44 PM   #1
1fine409
1fine409's Avatar
Need help setting starter on 400 sbc
I have a new high torque mini starter for my built 400, and i am having trouble setting the clearances. My bendix gear to flexplate clearance is fine, but I am having to install shims between the starter head and the block (obviously), but I have gone up to 1/8th in. in shims and the starter bendix engages the flywheel sometimes, but not everytime I crank. I am not starting the motor when I do this, just simply bumping the starter to see if it engages. Sometimes it will engage two or three times, then the fourth bump the bendix just grinds on the flywheel. I am afraid if I shim it any further away from the block my backlash on the teeth may be too much. I am almost positive the starter should be able to engage any time you crank it, whether the engine has started or not..? Any help is appreciated.
Thanks, Dusty
1fine409 is offline   Reply With Quote
